The HyperX Pulsefire Mat Gaming Mouse Pad is built for durability and precision tracking with a highly optimized surface and anti-fray stitching. With an anti-slip rubber underside and comfortable padding, you can enhance your gaming and your comfort. The flat surface provides a smooth, consistent mouse glide and it rolls up for easy portability. Pulsefire Mat is available in a variety of size options to accommodate for different play styles and space requirements.
                Seamless, anti-fray stitchingThe seamless anti-fray stitched edges provide resistance to daily wear and tear.
                Densely woven cloth surface tuned for precisionGet a smooth, consistent glide thanks to the precision surface. It's designed to be durable, rollable, and portable.
                Anti-slip rubber base and comfortable paddingThe textured rubber underside grips tight to keep the mouse pad in place during gameplay. Play comfortably on the soft cloth surfaced with inner foam padding.
- HyperX Pulsefire Mat mouse pad - gaming - medium
- Product Type
- Mouse pad
- Size
- Medium
- Product Material
- Cloth, rubber
- 360 mm x 300 mm x 3 mm
- 220 g
- Black
- 2-year warranty
- Designed For
- OMEN 25L by HP; 40L by HP; 45L by HP; Victus 15L by HP; Victus by HP Laptop 15, 16; HP 250 G9; Elite 600 G9, 800 G9; EliteDesk 800 G6; Laptop 14, 15, 15s, 17; Pavilion 24, 27; Pavilion Plus Laptop 14; Pavilion x360 Laptop; Pro 290 G9
- Product Type
- Mouse pad
- Size
- Medium
- Product Material
- Cloth, rubber
- 360 mm
- 300 mm
- 3 mm
- Thickness
- 3 mm
- 220 g
- Black
- Anti-fraying stitched edges, anti-slip rubberised base, wear-resistant, tear-resistant, flush, rollable, portable
- Limited warranty - 2 years
- Designed For
- OMEN 25L by HP GT14-0010nl , OMEN 40L by HP GT21-0024nl , OMEN 45L by HP GT22-0024nl , Victus 15L by HP TG02-0153nf, TG02-0314nf , Victus by HP Laptop 15-fa0001nq, 15-fa0002nq, 15-fa0004nq, 15-fa0008nq, 15-fa0014ns, 15-fa0022nq, 15-fb0000nm, 15-fb0026nm, 15-fb0136nf, 16-d0026nb, 16-d0354TX, 16-d1025nl, 16-d1034ns, 16-e0021nl, 16-e0022nl, 16-e0042nl, 16-e0054nl, 16-e0314nf, 16-e1003ny, 16-e1005nq, 16-e1010ca, 16-e1020ca, 16-e1900ng , HP 250 G9 Notebook , HP Elite 600 G9, 800 G9 , HP EliteDesk 800 G6 , HP Laptop 14-dq3210ca, 14-fq0200ca, 14-fq0210ca, 15-dw1025nk, 15-dw4030nm, 15s-eq1018ny, 15s-eq2049np, 15s-eq2050np, 15s-eq2056nb, 15s-eq2083nl, 15s-eq2083ns, 15s-eq3005nl, 15s-eq3016nl, 15s-eq3020nl, 15s-eq3621nd, 15s-fq2119nl, 15s-fq4030nl, 17-cn1006ns, 17-cn2004nm, 17-cn2048nm, 17-cn2267st, 17-cn2775st, 17-cp1620nd , HP Pavilion 24-ca1005ng, 24-ca1012ng, 27-ca1006ng, 27-ca1008ng, 27-ca1102ng, 27-ca1734nz, 27-ca2077no , HP Pavilion Plus Laptop 14-eh0660nd , HP Pavilion x360 Laptop 14-ek0005nm, 14-ek1006nb, 15-er1003nm , HP Pro 290 G9
