HyperX Pulsefire Core Gaming Mouse
Quicklinx: HTRKWS00 Mfr#: 4P4F8AA
Type: Mouse
More than 50 In Stock
£28.11 ex VAT
£33.73 inc VAT
The HyperX Pulsefire Core delivers the essentials for gamers looking for a solid, comfortable, wired RGB gaming mouse. The Pixart 3327 optical sensor gives players precise, smooth tracking with no hardware acceleration, and has native DPI settings up to 6200 DPI. The ergonomically-designed Pulsefire Core has textured side grips for a comfortable, no-slip grip, and its symmetrical shape is suitable for both palm and claw grip. It features high-quality switches with crisp tactile feedback rated for up to 20 million clicks. Customize lighting, DPI settings, and macros for 7 programmable buttons with HyperX NGENUITY software and set your mouse up just the way you want it. The large skates on Pulsefire Core help deliver accurate aiming by giving you a smooth, controlled glide as you move the mouse.
  • Pixart 3327 optical sensor
    The solid Pixart 3327 sensor provides precise tracking without hardware acceleration and supports native DPI settings up to 6200.
  • Seven programmable buttons
    Pulsefire Core features seven programmable buttons with switches that provide crisp tactile feedback and are rated for 20 million clicks.
  • Adjustable RGB lighting
    Add an individual touch of RGB style to your setup.
HyperX Pulsefire Core - mouse - USB 2.0
Mouse
Wired - USB 2.0
86.2 g
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
6200 dpi
Performance
Realtime sensitivity switching 800/1600/2400/3200 dpi, 20 million clicks, 220 ips tracking speed
Gaming
RGB colour LED, Pixart PAW 3327 optical gaming sensor, 30G acceleration
Cable Length
1.8 m
Victus by HP Laptop 15, 16; HP 250 G9; Elite 800 G9; EliteDesk 800 G6; Laptop 14, 15, 15s, 17; Pavilion Plus Laptop 14; Pavilion x360 Laptop; Pro 290 G9
Mouse
Gaming
86.2 g
Input Device
Wired
USB 2.0
Optical
Buttons Qty
7
Movement Resolution
6200 dpi
Performance
Cable Length
1.8 m
Software Included
HyperX NGenuity Software
Victus by HP Laptop 15-fa0014ns, 16-d0026nb, 16-d1025nl, 16-e0021nl, 16-e0022nl, 16-e0054nl, 16-e0314nf, 16-e1900ng , HP 250 G9 Notebook , HP Elite 800 G9 , HP EliteDesk 800 G6 , HP Laptop 14-dq3210ca, 14-fq0200ca, 14-fq0210ca, 15-dw1025nk, 15s-eq1018ny, 15s-eq2049np, 15s-eq2050np, 15s-eq2083nl, 15s-eq2083ns, 15s-eq3005nl, 15s-eq3016nl, 15s-eq3020nl, 15s-eq3621nd, 15s-fq2119nl, 15s-fq4030nl, 17-cn1006ns, 17-cn2267st, 17-cn2775st, 17-cp1620nd , HP Pavilion Plus Laptop 14-eh0660nd , HP Pavilion x360 Laptop 15-er1003nm , HP Pro 290 G9
Type: Mouse
Brand: HyperX
