HyperX Kingston 8GB 2133MHz DDR3L CL11 SODIMM 1.35V HyperX Impact Black
Quicklinx: B67KWS00 Mfr#: HX321LS11IB2/8
HyperX Impact memory boasts the world's fast SO-DIMM frequency - 2666 MHz - to keep you ahead of the curve and level up your game. It automatically recognizes the platform it's plugged into and auto overclocks to the high frequency published with no need to adjust system BIOS settings. So you get extreme performance that supports notebooks and other small form factor systems using either AMD or the Intel CPU technologies with no hassle at all - even if you're a newbie.
HyperX Impact Black Series - DDR3L - module - 8 GB - SO-DIMM 204-pin - 2133 MHz / PC3L-17000 - unbuffered
Memory module
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3L-17000)
Latency Timings
CL11 (11-12-13)
Dual rank, eight banks, On-Die Termination (ODT), Low Voltage, Black PCB, unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-12-13)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
RAM Performance
SPD - 1600 MHz - 1.35 / 1.5 V - CL9 - 9-9-10 , SPD - 1866 MHz - 1.35 / 1.5 V - CL10 - 10-11-12 , SPD - 2133 MHz - 1.35 / 1.5 V - CL11 - 11-12-13
