Get your notebook or SFF machine ahead of the curve with HyperX® Impact DDR4 SODIMM and drop the hammer on system lag. It’s optimized for Intel’s Series 100 and 200 chipsets and tested for compatibility with leading motherboard manufacturers. Available in capacities up to 64GB, it boasts low CL13, CL14 and CL15 latencies, higher memory bandwidth and speeds up to 2666MHz to annihilate in-game jitters. It auto-overclocks for max performance and runs efficiently at 1.2V.
- HyperX Impact - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2666 MHz / PC4-21300 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2666 MHz (PC4-21300)
- Latency Timings
- CL15 (15-17-17)
- Dual rank, On-Die Termination (ODT), Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL15 (15-17-17)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Colour Category
- Black
