HyperX Impact 8GB DDR4 2400MHz CL14 SODIMM Memory
Quicklinx: CWCXWS00 Mfr#: HX424S14IB2/8
Kingston HyperX Impact - DDR4 - 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - CL14 - 1.2 V - unbuffered - non-ECC
HyperX Impact - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL14 (14-14-14)
On-Die Termination (ODT), Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL14 (14-14-14)
Non-ECC
Module Configuration
1024 x 64
Voltage
1.2 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL13 - 13-13-13 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL14 - 14-14-14
Colour Category
