HyperX Impact 32GB (4x8GB) DDR4 2133MHz CL14 SODIMM Memory
Quicklinx: CWCWWS00 Mfr#: HX421S14IB2K4/32
Kingston HyperX Impact - DDR4 - 32 GB: 4 x 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - CL14 - 1.2 V - unbuffered - non-ECC
HyperX Impact - DDR4 - kit - 32 GB: 4 x 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
Memory kit
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL14
On-Die Termination (ODT), Black PCB, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL14
Non-ECC
Module Configuration
1024 x 64
Voltage
1.2 V
Lead Plating
Gold
Colour Category
