HyperX FURY Red 64GB (4x16GB) DDR4 2400MHz CL15 DIMM Memory
Quicklinx: CSNYWS00 Mfr#: HX424C15FRK4/64
HyperX® FURY DDR4 automatically recognises the platform it’s plugged into and automatically overclocks to the highest frequency published, up to 2666MHz, for hassle-free, plug-and-play functionality. It delivers automatic top-level performance for motherboards featuring Intel’s 200 series and X99 chipsets and complements Intel’s 2, 4, 6, 8 and 10-core processors for faster video editing, 3D rendering, gaming and AI processing. Available in speeds from 2133MHz–2666MHz, CL14–16 latencies and capacities of 4GB, 8GB and 16GB single modules and 8GB–64GB kits, HyperX FURY DDR4 is a minimal investment in premium components that results in faster speeds, higher performance and enhanced reliability – plus it looks really cool. It stays cool, too, thanks to 1.2V power consumption resulting in less heat, with a lower voltage specification than DDR3. Its stylish, low-profile design complements the look of the latest PC hardware while helping you stand out from the crowd of squared designs.
  • Plug and play
    Get the speed you want, hassle free. HyperX FURY DDR4 is a product line that offers automatic overclocking to the high frequency.
  • Low power consumption
    DDR4's lower power requirements mean less heat and higher reliability. Low volts draw less power from your system, which results in a cooler and quieter PC.
  • Low profile stylish heat spreader
    Stand out from the crowd and show your style with FURY's asymmetrical signature heat spreader.
HyperX FURY - DDR4 - kit - 64 GB: 4 x 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory kit
64 GB: 4 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL15
On-Die Termination (ODT), Serial Presence Detect (SPD), Black PCB, quad channel, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
64 GB: 4 x 16 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL15
Non-ECC
Module Configuration
2048 x 64
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
Colour Category
Red
