HyperX® FURY DDR4 automatically recognises the platform it’s plugged into and automatically overclocks to the highest frequency published, up to 2666MHz, for hassle-free, plug-and-play functionality. It delivers automatic top-level performance for motherboards featuring Intel’s 200 series and X99 chipsets and complements Intel’s 2, 4, 6, 8 and 10-core processors for faster video editing, 3D rendering, gaming and AI processing. Available in speeds from 2133MHz–2666MHz, CL14–16 latencies and capacities of 4GB, 8GB and 16GB single modules and 8GB–64GB kits, HyperX FURY DDR4 is a minimal investment in premium components that results in faster speeds, higher performance and enhanced reliability – plus it looks really cool. It stays cool, too, thanks to 1.2V power consumption resulting in less heat, with a lower voltage specification than DDR3. Its stylish, low-profile design complements the look of the latest PC hardware while helping you stand out from the crowd of squared designs.
Plug and play
Get the speed you want, hassle free. HyperX FURY DDR4 is the first product line to offer automatic overclocking up to the highest frequency published. -
Low power consumption
DDR4's lower power requirements mean less heat and higher reliability. Low 1.2 volts draw less power from your system, which results in a cooler and quieter PC. -
Low profile stylish heat spreader
Stand out from the crowd and show your style with FURY's asymmetrical signature heat spreader.
- HyperX FURY - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 32 GB: 2 x 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL14 (14-14-14)
- Dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), dual channel, Black PCB, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 32 GB: 2 x 16 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Module Height (inch)
- 1.34
- Speed
- Latency Timings
- CL14 (14-14-14)
- Non-ECC
- Module Configuration
- 2048 x 64
- Chips Organization
- 1024 x 8
- Voltage
- 1.2 V
- Lead Plating
- Gold
- RAM Performance
- SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2133 MHz - 1.2 V - CL14 - 14-14-14
- Colour Category
- Red
