HyperX Cloud Revolver S is primed for action with Plug N Play surround 7.1 audio. Hear every footstep, explosion and gunshot with cinematic clarity as the simulated seven positional speakers provide precise sound with distance and depth. The advanced USB digital signal processing sound card handles everything, delivering consistent premium-quality sound, no matter what system you're playing on. Backlit buttons on the clippable audio control box allow you to quickly activate audio, mute and regulate mic and output levels. Bass boost and vocal equalizer modes let you swap between setups tuned for games, streaming, music or movies. Revolver S has a studio-grade sound stage that excels in FPS and open environment settings, letting you hear sounds further away more accurately.
The unique Revolver S driver design separates the lows, mids and highs and the re-engineered profiles produce sounds audiophiles will rave about. Serious gamers and streamers will love the higher-quality dense HyperX signature memory foam and the wider headband that reduces head pressure and more evenly distributes weight. Cloud Revolver S has a solid-steel frame for long-lasting durability and stability and is built to deliver sonic perfection for years. Closed ear cups block out outside noise to fully immerse you in Cloud's signature crisp, clear sound quality and enhanced bass.
Plug N Play surround 7.1 audio technology
HyperX Cloud Revolver S is ready for battle with Plug N Play surround 7.1 audio. Make every part of your audio experience shine with cinematic clarity. -
Advanced USB audio control box with DSP sound card
The Digital Signal Processing sound card boosts your audio and enhances noise cancellation for an optimized gaming experience. Backlit buttons allow you to mute and adjust mic and output levels instantly with the clippable audio control box. -
Studio-grade sound stage lets you hear enemies before they hear you
Revolver S features a studio-grade sound stage that excels in FPS and open environment settings, allowing you to accurately hear sounds from further away, giving you an edge on the enemy. -
Next-generation directional drivers pump out crisp, precise audio
Directional drivers positioned parallel to the ears crank out crisp, precise audio with enhanced bass.
- HyperX Cloud Revolver S - headset - USB, 3.5 mm jack
- Product Type
- Headset - wired - USB, 3.5 mm jack
- Compatibility
- Mac, Windows
- Recommended Use
- Game console, portable electronics, computer
- Localisation
- EMEA
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Sound Effects
- 7.1 Channel Virtual Surround Sound
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 100.5 dB/mW
- Impedance
- 30 Ohm
- Max Input Power
- 500 mW
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Uni-directional
- Controls
- Mute, volume
- Product Type
- Compatibility
- Mac, Windows
- 376 g
- Body Material
- Steel
- Earpad Material
- Memory foam
- Recommended Use
- Localisation
- EMEA
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- 12 - 28000 Hz
- Max Input Power
- 500 mW
- Total Harmonic Distortion (THD)
- <2%
- Sensitivity
- 100.5 dB/mW
- Impedance
- 30 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Uni-directional
- Sensitivity
- -40 dB
- 50 - 18000 Hz
- Audio Input Details
- Uni-directional - 50 - 18000 Hz
Remote Control
- Controls
- Mute, volume
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Cable Length
- 1 m
- Included Accessories
- External USB control box, detachable microphone
- Cable Details
- Audio extension cable
