HyperX Cloud is designed to meet the demands of serious console gamers. Cloud in silver has convenient in-line audio control that saves you from navigating through system menus and puts control at your fingertips. The durable aluminum frame is designed for long-lasting reliability and to withstand the damage of daily gaming. The 100% memory foam ear cushions and leatherette-padded headband provide amazing comfort for those long weekends and late nights of gaming. HiFi capable 53mm drivers and enhanced bass reproduction pump out crystal clear high, mids and lows, and the closed cup design silences the outside world to completely immerse you in your game. Cloud's microphone can be adjusted the way you like it, and it eliminates background noise so you come across loud and clear. When you're ready to listen to music, simply unplug the microphone and stow it for later.
In-line audio control
Cloud in silver features in-line audio control designed with console gamers in mind; players will no longer have to navigate system menus to adjust volume and mute the microphone. -
Durable aluminum frame
Cloud is constructed with a durable aluminum frame that provides long-lasting durability. -
Award-winning comfort
100% memory foam cushions and leatherette-padded headband provide award-winning comfort so you can enjoy marathon gaming sessions without pain. -
Immersive in-game audio
HyperX Cloud's HiFi capable 533mm drivers and enhanced bass reproduction pump out crisp high-end, vibrant midrange and rich lows. The closed cup design blocks out outside noise to provide total gaming immersion. -
Detachable noise-cancellation microphone
The adjustable, noise-canceling microphone eliminates background noise so you'll be confident that you're communicating loud and clear. When it's time to listen to music, simply unplug the detachable microphone. -
TeamSpeak and Discord Certified
HyperX Cloud has been certified by TeamSpeak and Discord and is compatible with Skype, Ventrilo, Mumble, RaidCall and many other programs. During testing, no audible echoes, background noise or voice distortions were detected, so your team will have crystal-clear communication with Cloud. -
Distinctive style with ample accessories
Cloud in silver provides you yet another HyperX style to choose from and comes with a highquality mesh travel pouch to hold the headset, detachable mic and the 2M PC extension cable.
- HyperX Cloud Silver - headset - 3.5 mm jack
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Game console, portable electronics, computer
- Localisation
- North America
- Silver
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
- Impedance
- 60 Ohm
- Max Input Power
- 300 mW
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Uni-directional
- Controls
- Volume, microphone on/mute
- Product Type
- 322 g
- Silver
- Body Material
- Aluminium
- Headband Material
- Leatherette
- Earpad Material
- Memory foam
- Recommended Use
- Localisation
- North America
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 15 - 25000 Hz
- Max Input Power
- 300 mW
- Total Harmonic Distortion (THD)
- <2%
- Sensitivity
- 98 dB
- Impedance
- 60 Ohm
- Diaphragm
- 53 mm
- Magnet Material
- Neodymium
- In-Cord Volume Control
Microphone
- Boom
- Form Factor
- Detachable headset microphone
- Uni-directional
- Sensitivity
- -39 dB
- 50 - 18000 Hz
- Audio Input Details
- Uni-directional - 50 - 18000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Cable Length
- 1.3 m
- Included Accessories
- Detachable microphone
- Cable Details
- Headset cable - 1.3 m , Headset extension cable - 2 m
