HyperX Cloud Core has leatherette memory foam ear pads and a supersoft padded leatherette headband for maximum comfort, even when you're stuck in an endless battle. It delivers ear-pleasing performance with crystal-clear lows, mids and highs, enhanced bass reproduction and the same audio specs as the award-winning HyperX Cloud headset. It's pro-gaming optimized, with a detachable microphone and the distinctive HyperX design, and TeamSpeak certified.
- HyperX Cloud Core - headset
- Product Type
- Headset - wired
- Compatibility
- iPhone, iPad, Android phone, Windows
- Recommended Use
- Game console, portable electronics, computer
- Localisation
- EMEA
- Black, red
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 15 - 25000 Hz - Sensitivity 98 dB
- Impedance
- 60 Ohm
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- 2-year warranty
- Product Type
- Headset - wired
- Compatibility
- 320 g
- Black, red
- Body Material
- Leatherette
- Earpad Material
- Leatherette, memory foam
- Recommended Use
- Localisation
- EMEA
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 15 - 25000 Hz
- Total Harmonic Distortion (THD)
- 2%
- Sensitivity
- 98 dB
- Impedance
- 60 Ohm
- Diaphragm
- 53 mm
Microphone
- Boom
- Sensitivity
- -39 dB
- Impedance
- 2.2 kOhm
- Microphone Power Source Voltage (DC)
- 2 V
- 100 - 12000 Hz
- 2%
- Max Sound Pressure
- 105 dB
- Audio Input Details
- Cardioid - 100 - 12000 Hz
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole) , Microphone (mini-phone stereo 3.5 mm)
Cable
- Cable Length
- 1 m
- Cable Details
- Headset cable - 1 m , Headset extension cable - 2 m , Microphone cable - 15 cm
- Limited warranty - 2 years
