The OMNIKEY 3121 is a high-performance smart card reader for desktop use with multiple standing options in a robust housing. It is an easy-to-install USB device suited for all contact smart card operations like online-banking or digital signature applications.
 - HID OMNIKEY 3121 - SMART card reader - USB
 - SMART card reader - contact
- Interface Type
 - USB
 - 6.7 cm x 8 cm x 2.8 cm
 - 141 g
 - Two-tone grey
- OS Required
 - Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows CE .NET, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Server 2008, Microsoft Windows CE 6.0
- Microsoft Certification
 - Compatible with Windows 7
- Interface Type
 - USB
 - 6.7 cm
 - 8 cm
 - 2.8 cm
 - 141 g
 - Two-tone grey
- Expansion Slots
 - 1 x Smart Card
- Connections
 - 1 x USB - 4 pin USB Type A
- OK Notification
 - LED indicator
- Cables Included
 - 1 x USB cable - 1.8 m
- MTBF
 - 500,000 hour(s)
- Device Features
 - USB powered, vertical card slot
 - Plug and Play, ISO 7816, UL, VCCI, MIC, FCC, RoHS, WEEE, EMV 2000 level 1
- Electric Current Required
 - 60 mA
- OS Required
 - 0 °C
 - 55 °C
 - 10 - 90%
