Hypertec 4GB PC3-12800 DDR3L 1600MHz SODIMM Memory Module
Quicklinx: 9D81WS00 Mfr#: 0B47380-HY
Hypertec - DDR3L - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - 1.35 V - unbuffered - non-ECC - for Lenovo ThinkCentre M600; ThinkPad 11; L460; L560; P40 Yoga; P50; T460; ThinkPad Yoga 11
Hypertec - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Low Voltage, unbuffered
Voltage
1.35 V
IBM 0B47380
4 GB
Upgrade Type
System specific
IBM 0B47380
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
