Hypertec 4GB DIMM 240-pin DDR3 Memory Module
Quicklinx: 9J14WS00 Mfr#: 0A65729-HY
Hypertec - DDR3 - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for Lenovo S500; ThinkCentre E73; M73; M79; M83; M91; M92; M93; ThinkStation E32; P300
Hypertec - DDR3 - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
IBM 0A65729
Lenovo S500; ThinkCentre E73; ThinkCentre Edge 72; 92; ThinkCentre M72e; M73; M73e; M78; M79; M82; M83; M91; M91p; M92; M92p; M93; M93p; ThinkStation E30; E31; E32; P300
4 GB
Upgrade Type
System specific
IBM 0A65729
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Lenovo S500 10HS, 10HV , Lenovo ThinkCentre E73 10AS, 10AU , Lenovo ThinkCentre Edge 72 3484, 3485, 3492, 3493, 3497 , Lenovo ThinkCentre Edge 92 1855, 3376, 3377, 3387, 3388 , Lenovo ThinkCentre M72e 0896, 0900, 0958, 0967, 3578, 3597, 3598, 3655, 3660, 3662, 3664, 3665, 3668, 3675 , Lenovo ThinkCentre M73 10B0, 10B1, 10B2, 10B3, 10B4, 10B5, 10B6, 10B7 , Lenovo ThinkCentre M73e 10B0, 10B2, 10B6 , Lenovo ThinkCentre M78 10BN, 10BQ, 10BR, 10BS, 10BT, 10BU, 1562, 1565, 1766, 2111, 2113, 2114, 4865, 5100 , Lenovo ThinkCentre M79 , Lenovo ThinkCentre M82 2697, 2698, 2742, 2750, 2756, 2800, 2929, 2932, 3302, 3306, 3392, 3395 , Lenovo ThinkCentre M83 10AG, 10AH, 10AJ, 10AK, 10AL, 10AM, 10AN, 10BE , Lenovo ThinkCentre M91 4514, 4517, 7035, 7049 , Lenovo ThinkCentre M91p 4466, 4468, 4480, 4495, 4512, 4513, 4518, 4524, 7005, 7021, 7023, 7033, 7034, 7052, 7072 , Lenovo ThinkCentre M92 2982, 2993, 2994, 3207, 3208, 3224, 3226 , Lenovo ThinkCentre M92p 2943, 2988, 2992, 2996, 2999, 3209, 3212, 3218, 3220, 3227, 3228 , Lenovo ThinkCentre M93 10A0, 10A2, 10A3 , Lenovo ThinkCentre M93p 10A7, 10A9 , Lenovo ThinkStation E30 7782, 7783, 7824 , Lenovo ThinkStation E31 2552, 2553, 2555, 3688, 3690, 3691, 3695 , Lenovo ThinkStation E32 30A1, 30A3 , Lenovo ThinkStation P300 30AH, 30AK
