Hypertec 4GB 1600MHz SODIMM 204-pin Memory Module
Quicklinx: 9X6LWS00 Mfr#: HYMSO7304G-LV
Hypertec - DDR3 - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - 1.35 V - unbuffered - non-ECC
Hypertec - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Low Voltage, unbuffered
Voltage
1.35 V
4 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
