Hypertec 2GB PC3-12800 240-pin 1600 MHz DIMM Memory Module
Quicklinx: 9D7TWS00 Mfr#: B4U35AA-HY
Hypertec - DDR3 - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered - non-ECC - for HP 280 G1 (micro tower), 6300 Pro, 6305 Pro, Elite 8300 (CMT, MT, SFF)
Hypertec Legacy - DDR3 - module - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
HP B4U35AA
HP 280 G1, 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
2 GB
Upgrade Type
System specific
HP B4U35AA
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HP 280 G1 , HP Compaq 6300 Pro, 6305 Pro, Elite 8300 (DIMM)
