- Hypertec - DDR3 - module - 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- HP 497157-D88
- Limited lifetime warranty
- Designed For
- HP 600B
- Capacity
- 2 GB
- Upgrade Type
- System specific
- HP 497157-D88
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HP 600B
