Hypertec 1GB PC2-4200 64X8 200 SODIMM Memory Module
Quicklinx: 9D77WS00 Mfr#: HYS2426481GBOE
Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
Hypertec Legacy - DDR2 - module - 1 GB - SO-DIMM 200-pin - 533 MHz / PC2-4200 - unbuffered
Memory module
1 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
533 MHz (PC2-4200)
Unbuffered
1 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
SO-DIMM 200-pin
Speed
533 MHz (PC2-4200)
Non-ECC
Unbuffered
Chips Organization
64 x 8
Compatible Slots
1 x memory - SO-DIMM 200-pin
