Hypertec provides PC enhancement solutions that enable you to get maximum performance and comfort from your IT equipment, with minimum fuss.
From Matched Memory and Storage to peripherals; DVD Duplication Units to Ergonomic Workstation Equipment, Laptop Luggage and Security Products, Hypertec provides a complete solution to your needs.
Hypertec has spent over 20 years as a leading figure in the IT industry and working with the top resellers, so you can have confidence that we know what we're doing.
- Hypertec Legacy - DDR2 - module - 1 GB - SO-DIMM 200-pin - 533 MHz / PC2-4200 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 533 MHz (PC2-4200)
- Unbuffered
- Limited lifetime warranty
- Capacity
- 1 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Non-ECC
- Unbuffered
- Chips Organization
- 64 x 8
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
