Hynix 512GB M.2 SC300 Series SK SSD
Quicklinx: C1DNWS00 Mfr#: HFS512G39MND-3510A
SC300 is the Pure SSD (Solid State Drive) which adopts the latest SK hynix16nm NAND Flash Memory as main storage media. It has optimized power and performance features for today’s Note PC, Ultra-book PC and Tablet PC.
The SC300 M.2 product provides a capacity range from 128GB to 512GB, supports SATA3 6.0Gbps interface, and a small form factor of 22x80x2.23mm. SC300 can support up to 32 NAND Flash dies, and can perform up to 530MB/s during a Sequential Read.
Battery life is a vital factor for a Mobile PC, so SC300 supports not only the two SATA power management standard features called HIPM (Host Initiate Power Management) and DIPM (Device Initiate Power Management) but also the newly proposed feature, Devslpmode. SC300 M.2 is designed such that consumes less than 3mW in Devslpmode, which uses the least amount power in the PC user environment.
Since SC300 M.2 uses NAND Flash, performance can be degraded as the fragmentation occurs. SC300 M.2 is designed to recover from NAND degradation by providing TRIM functions. For reliability, SC300 supports 1.2M Hour MTBF, and End to End Data Protection function against any soft errors.
SC300 is also certified with UL, FCC, CE, TUV, KCC, BSMI, VCCI, C-Tick, CAN
SK Hynix SC300 - SSD - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
NAND Flash Memory Type
Multi-level cell (MLC)
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Temperature sensor, S.M.A.R.T.
22 mm x 80 mm x 2.23 mm
7 g
3-year warranty
512 GB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
2.23 mm
7 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
530 MBps (read) / 470 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
85000 IOPS
Average Latency
135 µs
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
0.06 Watt (active) , 0.045 Watt (idle) , 0.003 Watt (sleep)
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (operating)
20 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
