SK hynix SL308 2.5" SSD
A multi-tasking product boasting fast booting in various PCs, excellent durability, and outstanding speed.
A Superior PC Experience
In addition to enhanced performance, an SK hynix SL308 upgrade promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. With no moving parts, SSDs provide peace of mind with their superior durability and reliability.
TRIM Support
The SK hynix SL308 offers native TRIM support featured in Windows 7 and up. Designed to maintain the performance of SSD at an optimal level over the lifetime of the drive, TRIM functions by actively deleting invalid data from the SSD’s memory cells to ensure that write operations perform at full speed. Since a memory block must be erased before it can be re-programmed, TRIM improves performance by pro-actively erasing pages containing invalid data, allowing the SSD to write new data without first having to perform a time-consuming erase command.
S.M.A.R.T. Technology
The SK hynix SL308 adopts Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.) which enables the PC to predict the future failure of hard disk drives. Through the SMART system, hard disk drives incorporate a suite of advanced diagnostics that monitor the internal operations of a drive and provide an early warning for many types of potential problems. When a potential problem is detected, the hard drive can be repaired or replaced before any data is lost or damaged.
- SK Hynix "CANVAS" SL300 Series SL308 - SSD - 250 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 250 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 60 g
- 3-year warranty
- Capacity
- 250 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
- 60 g
Performance
- SSD Endurance
- 75 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 490 MBps (write)
- 4KB Random Read
- 100000 IOPS
- 4KB Random Write
- 85000 IOPS
Reliability
- MTBF
- 1,500,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 0.05 Watt (idle) , 2.3 Watt (read) , 3 Watt (write)
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 95 °C
- 5 - 95%
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (operating)
- 20 g @ 10-2000 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
