SC300 is the Pure SSD (Solid State Drive) which adopts the latest SK hynix16nm NAND Flash Memory as main storage media. It has optimized power and performance features for today’s Note PC, Ultra-book PC and Tablet PC.
The SC300 mSATA product provides a capacity range from 128GB to 512GB, supports SATA3 6.0Gbps interface, and a small form factor of 30x51x3.7mm. SC300 can support up to 32 NAND Flash dies, and can perform up to 530MB/s during a Sequential Read.
Battery life is a vital factor for a Mobile PC, SC300 supports not only the two SATA power management standard features called HIPM (Host Initiate Power Management) and DIPM (Device Initiate Power Management) but also the newly proposed feature, Devslp mode. SC300 mSATA is designed such that consumes less than 3mW in Devslpmode, which uses the least amount power in the PC user environment.
Since SC300 mSATA uses NAND Flash performance can be degraded as the fragmentation occurs.SC300 mSATA is designed to recover from NAND degradation by providing TRIM functions.For reliability, SC300 supports 1.2M Hour MTBF, and End to End Data Protection function against any soft errors.
SC300 is also certified with UL, FCC, CE, TUV, KCC, BSMI, VCCI, C-Tick, CAN
- SK Hynix SC300 - SSD - 128 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 128 GB
- NAND Flash Memory Type
- 16nm multi-level cell (MLC)
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Temperature sensor, S.M.A.R.T.
- 29.85 mm x 50.8 mm x 3.71 mm
- 8 g
- 3-year warranty
- Capacity
- 128 GB
- Form Factor
- mSATA
- Interface
- SATA 6Gb/s
- 29.85 mm
- 50.8 mm
- 3.71 mm
- 8 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 530 MBps (read) / 190 MBps (write)
- 4KB Random Read
- 85000 IOPS
- 4KB Random Write
- 50000 IOPS
- Average Latency
- 135 µs
Reliability
- MTBF
- 1,200,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 52 pin mini-SATA
- Compatible Bay
- mSATA
- Power Consumption
- 0.06 Watt (active) , 0.045 Watt (idle) , 0.003 Watt (sleep)
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (operating)
- 20 g @ 10-2000 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
