SK hynix Canvas SL300 Series SSDs are easy to use for everyone. Whether you are in your office, home or school, the lightweight SSD Canvas will help you do your job faster. You can save time and enjoy a more convenient life.
Intensive SSD
SK hynix SSD Canvas is designed to upgrade your PC easily. Upgrading with Canvas will increase speed and overall performance of your old PC. SK hynix data migration tool helps you to clone your valuable files and OS in hard drives to SK hynix SSD Canvas. -
Great total solution
NAND flash memory, controller, and DRAM are all developed in-house, to ensure powerful performance and outstanding stability.
- SK Hynix "CANVAS" SL300 Series SL301 - SSD - 250 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 250 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Temperature sensor, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 60 g
- 3-year warranty
- Capacity
- 250 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
- 60 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 470 MBps (write)
- 4KB Random Read
- 95000 IOPS
- 4KB Random Write
- 85000 IOPS
Reliability
- MTBF
- 1,200,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 0.05 Watt (idle) , 2.5 Watt (read) , 3 Watt (write)
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (operating)
- 20 g @ 10-2000 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
