Huawei P Smart+ 2019 - Midnight Black
Quicklinx: FBHFWS00 Mfr#: 51093RWA
  • microSDHC
  • Android
  • Bluetooth
The HUAWEI P smart+ 2019 features a classic unibody design. The ceramic-like finish is created with a NCVM+ flat spray process to be smooth and comfortable in your hand. Capture every unique moment effortlessly with three superior rear cameras. The HUAWEI P smart+ 2019 includes a main 24MP camera, ultra wide-angle 16MP lens and a 2MP bokeh camera. The Handheld Night Mode combined with AI Stabilization technology, produces incredibly clear handheld shots in low-light. Your night photos will be sharper, brighter and more pure. Get an ultra-broad view with superior color from any angle on the 6.21" FHD+ Dewdrop display. The 89% screen-to-body ratio provides more room for your fantastic videos and exciting games. The advanced GPU Turbo 2.0 effectively accelerates the graphics processing and improves the gaming performance, delivering a stable and smooth gaming experience. EMUI 9.0 provides a simple interactive design and intelligent functions for easier use. Your phone will learn to understand you and support for more efficiency in everyday tasks.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Superior triple camera
  • Ultra wide-angle lens
    The rear 16MP ultra-wide lens provides a super wide angle for every moment you see. You can view magnificent architecture, spectacular landscapes or exciting group photos and everything will be seen clearly.
  • AI selfie artist
    The front 8MP high-definition camera, supported by an AI smart algorithm, perfectly showcases your clear and outstanding selfies even in a backlit environment.
  • Handheld Night Mode
  • 480 fps slow motion
    Super slow motion video mode can record 480 fps on the HUAWEI P smart+ 2019. Have fun recording your unforgettable moments before they are gone.
  • FHD+ Dewdrop display
  • Classic unibody
  • Kirin 710
    Driven by the Kirin 710 chipset four A73 big cores, the running performance is enhanced to full-speed while the power consumption is efficiently lowered.
  • GPU Turbo 2.0
  • AI smart life
Huawei P Smart+ 2019 - midnight black - 4G smartphone - 64 GB - GSM
4G smartphone
Display
2340 x 1080 pixels - 6.21" - 19.5:9
HiSilicon Kirin 710 (8-core) - 64-bit
RAM 3 GB / 64 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 9.0 Pie with HUAWEI Emotion UI 9.0
Main Camera
24 Megapixel focus: automatic
Second Camera
2 Megapixel
Third Camera
16 Megapixel - ultra wide-angle lens
Front Camera
8 Megapixel - focus free
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
Bluetooth, Wi-Fi
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Midnight black
73.4 mm x 7.95 mm x 155.2 mm
160 g
0.83 W/kg (head) , 1 W/kg (body)
Smartphone
Touch
73.4 mm
7.95 mm
155.2 mm
160 g
Body Colour
Midnight black
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
User Interface
Navigation
GPS, A-GPS, GLONASS
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
Wireless Interface
Bluetooth, Wi-Fi
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Ambient light sensor, digital compass, gravity sensor
Security Devices
Fingerprint reader
Additional Features
HiVision AI Translation, AI Smart Life, GPU Turbo 2.0 technology
HiSilicon Kirin 710
Processor Core Qty
8-core
64-bit Architecture
RAM
3 GB
Internal Memory Capacity
64 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Focus free
AI Selfie Artist
Main Camera
Sensor Resolution
24 Megapixel
Focus Adjustment
Automatic
Camera Modes
Night mode, Super slow motion
Light Source
LED light
AI Photography Artist, AI Triple camera
Second Camera
Sensor Resolution
2 Megapixel
Third Camera
Sensor Resolution
16 Megapixel
Lens Type
Display
Diagonal Size
6.21"
Display Resolution
2340 x 1080 pixels
Display Format
Full HD+
Aspect Ratio
19.5:9
FullView Display, Dewdrop display
Connector Type
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
3400 mAh
TUV Rheinland Eye Comfort Certification
Headset, USB cable, power adapter, SIM card removal tool
