Huawei Matebook 13 AMD Ryzen 5 8GB 512GB Win10 Laptop
Quicklinx: G6JGWS00 Mfr#: 53010YSF
  • IEEE 802.11n
Seeing is Believing
13-inch FullView Display and 88% screen-to-body ratio bring to life an immersive visual experience.
Bright and Vivid
2K display (2160 x 1440 resolution) , 100% sRGB (typical capacity) colour gamut, 3:2 aspect ratio
Feel the Force
AMD Ryzen 5 3500U processor, integrated 4-core, and 8-thread computing power on a 12 mm process.
Rapid Heat Dissipation
HUAWEI's new Shark Fin 2.0 fan design can dissipate heat faster than ever by using dual fans.
Don't Just Hear It, Feel It
HUAWEI MateBook 13 features Dolby Atmos immersive audio, creating an amazing acoustic experience.
HUAWEI Share
With just a simple tap, your smartphone and Huawei MateBook will transform into "ONE" super device even without Internet connection. Your phone screen appears on your laptop which allows you to drag and drop files between them, and edit the files on your laptop while messaging.
Enjoy Longer
The 41.7 Wh large battery keeps you powered-up for longer. It can be charged to 50% in only 30 mins.
Ready, Press, Go
Fingerprint Power Button with optimised BIOS lets you power up and quickly login by one step.
Specs
Model: 53010YSF
Matebook 13 2020
Colour: Grey
Display size: 13"
Processor: AMD Ryzen 5 3500U 2.4GHz
RAM: 8 GB
Hard Disk: 512GB SSD
USB 3.0 Ports x 2
Operating System: Windows 10 Home
Average Battery Life: 11 Hours
Weight: 2.25 kg
  • Bright and vivid
    Offering 2K display (2160 x 1440 resolution) with 100% sRGB (typical capacity) color gamut, HUAWEI MateBook 13 presents bright and lively visuals with rich details. The 3:2 aspect ratio is perfect for reading and writing, and the 300 nits (typical capacity) brightness ensures a pleasant viewing experience with clear contrast and color depth.
  • Body & soul
    Weighing just 1.31 kg, HUAWEI MateBook 13 is optimal for portability, and its robust build is for lasting enjoyment. Its slimline 14.9 mm metallic frame is meticulously crafted with a diamond cut finish on each corner, giving it an ultra-modern premium look and feel. A powerfully elegant machine.
  • Feel the force
    Powered by the AMD Ryzen 5 3500U processor, integrated 4-core, and 8-thread computing power on a 12 mm process, HUAWEI MateBook 13 outperforms 12% on multi-core performance. Thanks to the new generation Radeon Vega 8 Graphics, its visual performance is also enhanced by 11%. A laptop with optimal balance of power efficiency and performance.
  • Rapid response, vast space
    Fitted with a PCIe NVMe high-speed SSD, and packing up dual-channel architecture DDR4 RAM, HUAWEI MateBook 13 provides five-times the read capacity and three-times the write capacity than that of SATA SSDs. The maximum read and write speed has been improved by more than 50% compared to single-channel memory design, dramatically reducing wait times while running programs or storing and reading data. Express your creativity freely with a smooth and robust experience.
  • Enjoy longer
    The 41.8 Wh (typical capacity) large battery keeps you powered-up for longer. It can be charged to 50% in only 30 minutes. Just take a break and you are good to go again.
  • Rapid heat dissipation
    HUAWEI's Shark Fin 2.0 fan design can dissipate heat faster by using dual fans, achieving a 25% speed increase than normal fans. It enhances air flow to cool the computer rapidly and quietly for a better working experience. With this technology, you can enjoy uninterrupted and smooth workflow even when running multiple apps or playing intense games.
Huawei Matebook 13 2020 AMD - 13" - AMD Ryzen 5 - 3500U - 8 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
AMD Ryzen 5 3500U
8 GB DDR4
Storage
512 GB SSD
Display
13" 2160 x 1440 / 2K - 200 ppi
Graphics
AMD Radeon Vega 8
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Ambient light sensor, hall sensor, Huawei Share sensor
Security
Fingerprint reader
Space grey
28.6 cm x 21.1 cm x 1.49 cm
1.3 kg
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
AMD Ryzen 5 3500U
RAM
8 GB
DDR4 SDRAM
Speed
2400 MHz
Storage
Main Storage
512 GB SSD PCIe
Display
13" - IPS
Resolution
2160 x 1440 (2K)
Widescreen
Pixel Density (ppi)
200
Image Aspect Ratio
3:2
Image Brightness
300 cd/m²
Colour Gamut
100% sRGB
Eye comfort mode, 178° viewing angle
Audio & Video
Graphics Processor
AMD Radeon Vega 8
Camera
Resolution
1 Megapixel (front)
Sound
Stereo speakers, two microphones
Input
Keyboard, touchpad
Keyboard Backlight
Chiclet keyboard
Communications
Wireless
Lithium polymer
41.7 Wh
Battery Run Time
Video playback: up to 11.6 hours
AC Adapter
Input
Output
65 Watt, 5 / 9 / 12 / 15 / 20 V, 3.25 A
Connections & Expansion
Interfaces Details
2 x USB-C , Headphone/microphone combo jack
Space grey
Case Material
Aluminum
Integrated Options
Security
Fingerprint reader
2x2 MiMo function
USB-C power adapter
USB-C charge cable
1.3 kg
40.6 cm x 28.2 cm x 8.5 cm / 1.95 kg
Sustainability Information
TCO Certified
