Built to meet the needs of demanding VR users, VIVE is an easy-to-deploy VR system that scales with your business and provides a rich feature set for professional users.
Experience games, films and other content in a entirely new more immersive way with a VR (Virtual Reality) headset. Choose from a wide range of models, from basic VR headsets designed for smartphones to PC compatible headsets such as the HTC Vive and Oculus Rift that include motion tracking and higher resolution displays.
SPATIAL AUDIO WITH NOISE CANCELLATION - hi-res, high impedance headphones, 3D spatial sound with active noise cancellation for an immersive experience without distractions from real-world.
MULTI-USER AND EXTENDED USE – Even weight distribution of the headset, easy on and off, and adjustments for head size, glasses and interpupillary distance (IPD) makes multi-user and extended use easier than ever.
VIVE TRACKER ECOSYSTEM - Expand business use cases by adding real-life objects to VIVE Tracker bringing the object into your virtual simulation. Ideal for motion capture, automotive, aerospace or heavy equipment simulation.
High-resolution display for precise clarity
VIVE features dual-OLED displays with an incredible resolution to make graphics, text and textures look perfectly crisp and clear, so you get the visual fidelity required for demanding use cases and environments. -
Engineered for comfort
Featuring even-weight distribution and a an increase in face gasket surface area, VIVE was ergonomically engineered to provide maximum comfort and flexibility, even with extended use.
- HTC VIVE Enterprise - Advantage - virtual reality system
- Virtual reality system
- Microphone
- Sensors
- Proximity sensor, gyro sensor, G-sensor, IPD sensor
- Native Resolution
- 2880 x 1600 at 90 Hz
- Resolution per Eye
- 3.5" - 1440 x 1600
- Field of View
- 110°
- Input Connectors
- DisplayPort
- DisplayPort 1.2
- 2-year warranty
- Display Type
- Virtual reality system / AMOLED
- Built-in Devices
- Microphone
- Native Resolution
VR Headset
- 1440 x 1600
- Diagonal Size per Eye
- 3.5"
- Field of View
- 110°
- Sensors
- Adjustable headband, interpupillary distance adjustment, SteamVR tracking technology, adjustable headphones, adjustable lens distance
Audio
- Headphone
- DisplayPort , Headphones , USB-C
- Bluetooth interface
- Included Accessories
- Earphone, cleaning cloth, 2 x HTC Vive wireless controllers, 2 base stations, link box, 2 x earphone hole caps
- Cables Included
- 1 x headset cable , 1 x USB cable , 1 x DisplayPort cable , 2 x micro-USB cable
- DisplayPort 1.2
- OS Required
- Windows 10, Windows 8.1 or later
- Limited warranty - 2 years
