HTC Google Nexus 9 32GB 8.9" Android 5.0 Lollipop - Black
Quicklinx: B29WWS00 Mfr#: 99HZF014-00
  • Android 5.0 (Lollipop)
With a soft grip back and subtle curves, the Nexus 9 tablet strikes a slim profile that's light and comfortable for work or play. Built with a thin bezel, brushed metal sides and clean lines, the Nexus 9 tablet is sleek and sturdy.
  • Fit for your hand
  • High-quality construction
  • Perfectly sized display
    The 8.9" screen is big enough to work and watch on, but small enough to carry around in one hand.
  • Crisp, clear sound
    Sound is more immersive, layered and distortion-free with front-facing HTC BoomSound speakers.
  • Powerful processor
    With the fast processor, easily move between tabs to check email, watch videos, and tweak docs - all at once.
  • From work to play and back again
    The magnetically attached, fully-responsive keyboard allows you to type at different angles. Sold separately, it helps you get stuff done at home, at the office, and on the go.
Google Nexus 9 - tablet - Android 5.0 (Lollipop) - 32 GB - 8.9"
Tablet
Operating System
Display
8.9" IPS TFT - 2048 x 1536
NVIDIA Tegra K1 (Dual-Core) - 64-bit
Processor Clock Speed
2.3 GHz
Storage
32 GB eMMC
RAM
2 GB
Wireless Connectivity
802.11a/b/g/n/ac, NFC, Bluetooth 4.1
Rear Camera
8 Megapixel focus: automatic
Front Camera
1.6 Megapixel
Navigation System
A-GPS/GPS/GLONASS
15.368 cm x 0.795 cm x 22.825 cm
436 g
Indigo black
Tablet
Operating System
Display
8.9" IPS TFT
Resolution
2048 x 1536
Image Aspect Ratio
4:3
Corning Gorilla glass 3
NVIDIA Tegra K1
2.3 GHz
Number of Cores
Dual-Core
64-bit Computing
Storage
32 GB eMMC
RAM
2 GB
Communications
Security Protocols & Features
DLNA, Wi-Fi Miracast
Rear Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Automatic
Light Source
Flash
Front Camera
Sensor Resolution
1.6 Megapixel
Navigation System
Receiver
A-GPS/GPS/GLONASS
Multimedia
Graphics
NVIDIA Kepler
Audio
Two microphones, stereo speakers
Expansion and Connectivity
1 x Micro-USB , 1 x audio line-out
AC 100/240 V / DC 5 V (50/60 Hz)
Lithium polymer
6700 mAh
Standby Time
Up to 720 h
Run Time Details
Web browsing over Wi-Fi: up to 9.5 hours , Video playback: up to 9.5 hours
Indigo black
Sensors
Accelerometer, ambient light sensor, digital compass, barometer, magnetometer, gyro sensor, G-sensor
MIMO technology
Power adapter
15.368 cm
0.795 cm
22.825 cm
436 g
