HPE X361 150W AC Reman Power Supply
Quicklinx: D0J3WS00 Mfr#: JD362B
Power Rating: 150watt
£194.02 ex VAT
£232.82 inc VAT
Marketing description is not available.
  • Efficient power supply
    Designed to meet the demands of network hardware, the HPE X361 offers a robust 150 W power supply. This ensures your network hardware operates efficiently without the risk of power shortage, making it a reliable choice for sustaining high-performance computing environments.
  • Versatile compatibility
    The HPE X361 is engineered for seamless integration with network hardware. Its power supply compatibility feature ensures it can support a wide range of network devices, providing a flexible solution for various networking needs.
HPE X361 - power supply - 150 watt
Power supply
1.5 kg
Power Capacity
150 watt
19.05 cm x 12.19 cm x 4.06 cm
HPE 5130-24G-4SFP+ 1-slot, 5130-24G-SFP-4SFP+, 5130-48G-4SFP+ 1-slot, 5500-24G, 5500-24G-4SFP, 5500-24G-SFP, 5500-48G-4SFP, 5510-24G-4SFP, 5510-24G-SFP, 5510-48G-4SFP, 5800-24G-SFP
Power supply
Power Capacity
150 watt
19.05 cm
12.19 cm
4.06 cm
1.5 kg
HPE 5130-24G-4SFP+ 1-slot HI, 5130-24G-SFP-4SFP+ EI, 5130-48G-4SFP+ 1-slot HI, 5500-24G HI TAA-compliant Switch with 2 Interface Slots, 5500-24G-4SFP HI Switch with 2 interface Slots, 5500-24G-SFP EI Switch, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5510-24G-4SFP HI Switch with 1 Interface Slot, 5510-24G-SFP HI Switch with 1 Interface Slot, 5510-48G-4SFP HI Switch with 1 Interface Slot, 5800-24G-SFP Switch
Brand: HPE
