HPE USB to Serial Port Adapter
Quicklinx: 9TMCWS00 Mfr#: J7B60AA
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£22.59 ex VAT
£27.10 inc VAT
Quickly and easily add a serial port to your desktop to connect to your serial and parallel peripherals with the HP USB Serial Port Adapter, which plugs into any USB port on your PC.
  • Easy to use
    Simply plug the adapter into any available USB 2.0 or 3.0 port on your PC and connect the other end to your serial or parallel device.
  • Solid data transfer speeds
    Enjoy USB connection speed up to 12 Mbps and serial communication speed up to 115.2 Kbps.
HP - serial adapter - USB - RS-232 x 1
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232 x 1
RS-232
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits)
HP 260 G4, 280 G4, 280 G5, 285 G6, 295 G6, Z1 G8; Desktop 280, Pro 300 G6, Pro A 300 G3, Pro A G2, Pro A G3; EliteDesk 705 G5, 800 G5, 800 G8, 805 G6; EliteOne 1000 G2, 800 G5, 800 G6, 800 G8; ProDesk 405 G4, 405 G6; ProOne 400 G4, 600 G6; RP9 G1 Retail System; Workstation Z1 G5, Z1 G6, Z1 G8
Serial adapter
External
USB
Ports
RS-232 x 1
Wired
RS-232
1 x RS-232 - 9 pin D-Sub (DB-9) - male
1 x USB / serial cable (integrated) - 1.2 m
Shipping Width
23.2 cm
Shipping Depth
18.4 cm
Shipping Height
3.9 cm
HP 260 G2, 260 G4, 280 G1, 280 G2, 280 G3, 280 G4, 280 G5, 285 G6, 290 G4, 295 G6, t430, t628, Z1 G8 , HP Desktop 280 Pro G5, Pro 300 G6, Pro A 300 G3, Pro A G2, Pro A G3 , HP Elite Slice, Slice for Meeting Rooms , HP EliteDesk 705 G4, 705 G5, 800 G5, 800 G8, 805 G6 , HP EliteOne 1000 G1, 1000 G2, 800 G3, 800 G5, 800 G6, 800 G8 , HP Pavilion Elite m9135.ch, Elite m9140.ch, Elite m9160.ch-a, Elite m9161.sc, Elite m9165.uk-a, Elite m9180.fr, Elite m9180.it, Elite m9180.nl, Elite m9180f, Elite m9190.nl, Elite m9380.it , HP ProDesk 400 G5, 405 G4, 405 G6, 600 G3, 600 G4 , HP ProOne 400 G3, 400 G4, 600 G3, 600 G6 , HP RP9 G1 Retail System 9015, 9018, 9118 , HP Workstation Z1 G5 Entry, Z1 G6 Entry, Z1 G8, Z1 G8 Entry
Brand: HPE
