HPE USB Dual Output USB Graphics Adapter
Quicklinx: 9R98WS00 Mfr#: C5U89AT
Increase screen real estate and productivity with a dual-monitor setup with the HP Dual Output USB Graphics Adapter, featuring DVI-I and DisplayPort outputs to drive displays at high resolutions through a single USB 3.0 B connection to your PC.
HP Dual Output USB Graphics Adapter - external video adapter - Smart Buy
External video adapter
Bus Type
SuperSpeed USB 3.0
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2048 x 1152 / DisplayPort: 2560 x 1600 / VGA: 1920 x 1200
Max Monitors Supported
2
Interfaces Details
DVI-I , DisplayPort , VGA - with adapter
8.14 cm x 9.45 cm x 2.01 cm
Manufacturer Selling Program
HP Smart Buy
HP 1155; EliteBook 725 G2 Notebook, 745 G2 Notebook, 755 G2 Notebook, 820 G2 Notebook, 840 G2 Notebook, 850 G2 Notebook; EliteBook Folio 1020 G1; ProBook 450 G2 Notebook; Spectre Pro x360 G1; ZBook 17 G3 Mobile Workstation, Studio G3 Mobile Workstation
Bus Type
SuperSpeed USB 3.0
Max Resolution
2560 x 1600
2
Interfaces Details
Microsoft Windows 7 (32/64 bits)
Min Processor Type
Dual core processor 2.4 GHz
Min RAM Size
2 GB
1 x DVI-VGA adapter , 1 x USB power splitter cable
UL, VCCI, C-Tick, FCC, KC
8.14 cm
9.45 cm
2.01 cm
HP Smart Buy
20 - 80%
HP 1155 , HP EliteBook 725 G2 Notebook, 745 G2 Notebook, 755 G2 Notebook, 820 G2 Notebook, 840 G2 Notebook, 850 G2 Notebook , HP EliteBook Folio 1020 G1 , HP ProBook 450 G2 Notebook , HP Spectre Pro x360 G1 , HP ZBook 17 G3 Mobile Workstation, Studio G3 Mobile Workstation
