HP sets the standard for performance and value in the enterprise with the Rack 10000 G2 Series family. This enterprise-class rack cabinet combines next-generation structural integrity cooling and cable management, ease of use capabilities and choice of configuration options to deliver a best-in-class product. The new HP 10000 G2 Series is designated as HP's universal rack, ideal for all HP server and storage platforms including Supports HP ProLiant, Integrity, BladeSystem, NonStop, StorageWorks MSA, EVA and XP. The HP 10000 G2 Series is specifically designed to ensure outstanding cooling and cable management making the 10000 G2 Series the best choice for enterprise racks.
Side Panels are not included.
- HPE Rack 10642 G2 Pallet - rack - 42U
- Product Type
- Rack
- Carbon, metallic graphite
- Rack Size
- 19"
- Height (Rack Units)
- 42U
- Product Material
- Metal
- 59.7 cm x 102 cm x 200 cm
- 114.8 kg
- 3-year warranty
- Designed For
- ProLiant DL120 G6, DL165 G7, DL320 G5p, DL320 G6, DL360 G6, DL360 G7, DL365, DL365 G5, DL370 G6, DL380 G5, DL380 G6, DL380 G7, DL385 G2, DL385 G5, DL385 G5p, DL385 G7, DL580 G7, DL585 G7, DL785 G5, DL980 G7, ML110 G7, ML310 G4, ML350 G6, ML370 G6, SL165s G7, SL165z G7, SL170z G6, SL2x170z G6
- Product Type
- Rack
- Product Material
- Metal
- Rack Size
- 19"
- 42U
- 59.7 cm
- 102 cm
- 200 cm
- 114.8 kg
- Weight Limit
- 908 kg
- RoHS, WEEE
- Limited warranty: parts - 3 years
- Designed For
- HPE Integrity BL60p , HPE ProLiant BL20p G3, BL20p G4, BL25p, BL480c, DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL165 G7, DL165 G7 Special Server, DL320 G4, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 Base, DL365 Entry, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G4, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL380 G5 Storage Server 2TB SATA Model, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL580 G4 High Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL980 G7, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML310 G3, ML310 G4 1TB Storage Server, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML570 G4, ML570 G4 High Performance, SL165s G7, SL165z G7, SL170z G6, SL2x170z G6
