Although HP media offers extreme reliability under a whole range of conditions, it is still advisable to follow a sensible procedure when handling and storing cartridges in order to maximize the life of your tapes. Many causes of recording or read errors are temporary and can be corrected by cleaning cartridge. Regular drive cleaning is essential to long-term reliability and should be conducted on a scheduled cycle as well as when requested by the drive.
This Universal Ultrium cleaning cartridge is designed for use with HP Ultrium drives shipped after January 2002 and for older drives with a firmware upgrade.
Reliable Offline Medium that Creates an Air Gap to Keep Data Out of the Reach of Cybercriminals
Agencies such as the US FBI recommend keeping data offline. This is because tapes that are stored offline are disconnected from the network and are out of reach of sophisticated criminals who use digital networks to strike at companies to encrypt both their primary data and their backups.Built-in AES 256-bit encryption (LTO-5 to LTO-9) allows you to provide additional security for data stored on tape. With LTO encryption (strengthened by the option to use WORM cartridges), even if tapes were to fall into the wrong hands, your data would be protected from unauthorized access.HPE LTO Ultrium cartridge memory chip delivers faster access time and enhanced media monitoring.First time restore ensured with fewer media failures and disrupted backups, regardless of duty cycle or environmental conditions. -
Lowest Total Cost of Ownership for Long-term Archiving
According to a white paper from ESG, 'The Economic Benefits of HPE StoreEver as Active Archival Storage', published in August 2020, LTO tape technology is over 80% less expensive across a 10-year period, than either all-disk or all-cloud solutions for a 1 PB archive growing at 10% per annum.Standardizing on HPE LTO Ultrium delivers the capacity to meet shrinking backup windows, industry-standard, AES 256-bit encryption (IEEE1619.1), and interchangeable read-write (RW) or WORM media; without extra space or IT resource overhead.Open standard technology helps ensure compatibility across product generations and gives you more choice. HPE LTO Ultrium cartridges are available as custom labeled or non-custom labeled.HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing).This ensures maximum reliability for restoring your data.HPE offers a limited lifetime warranty for HPE LTO Ultrium cartridges, including up to 30 years archival life, if stored at the recommended storage conditions. This ensures businesses can meet the ever-increasing demands of regulation for data retention and archiving. -
Highest Capacity and Performance of any Comparable Tape Technology
HPE LTO-9 Ultrium data cartridges can write or read data at a blistering native 1.44 TB/hour, storing, encrypting, and protecting up to 45 TB* on a single cartridge, making it ideal for large-scale, 24x7, mission-critical IT environments (*capacity assumes 2.5:1 compression).A 35% increase in the number of tracks and a 3% increase in bit density has permitted a capacity increase from 30 TB for LTO-8 to 45 TB for LTO-9. From 2,176 tracks for LTO-6 to 8,960 tracks for 9th generation HPE LTO-9 Ultrium 45 TB cartridges (assuming 2.5:1 compression) – an improvement of 311% -
Ultra-reliable Storage Medium
Tape is more reliable than enterprise SATA disk, with a bit error rate (BER) of 1x10 to the power of 19 for LTO-8 versus 1x10 to the power of 15 for enterprise SATA HDD's. That's a difference in reliability of four orders of magnitude–e.g. tape is 10,000 times more reliable than enterprise SATA HDD.Estimated data loss over 10 years for 1 Exabyte archive is 1.1 Petabytes for HDD compared to only 7.4 Terabytes for tape.HPE brand qualification test procedures (load/unload, shoeshine, drop testing and environmental stress testing) go far beyond what is required for the HPE LTO Ultrium. This ensure utmost reliability for restoring your data.Superior 'smart grabber' mechanism and mechanical interlock to prevent the leader pin from being pulled inside the tape housing. Sensors detect proper connection and prevent leader loss that would ruin the tape. Simplified tape path to reduce wear, tear, and build-up of debris–crucial in automation.User write-on labels are no longer included with A and W SKU's.
- HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium x 1 - cleaning cartridge
- Cleaning cartridge - LTO Ultrium
- Media Included Qty
- 1
- Orange
- 90 days warranty
- Designed For
- HPE MSL2024, MSL4048, T950, T950 3, T950 6; LTO-5 Ultrium; StorageWorks MSL2024, MSL4048, MSL6000, MSL6030, MSL6060, MSL8096, SAS Rack-Mount Kit, SB1760; StorageWorks 1/8 G2 Tape Autoloader; StoreEver MSL2024, MSL3040, MSL4048, MSL4048 LTO-5, MSL6480; SureStore Ultrium; Ultrium 448, 920
- 1
- Orange
- 11.2 cm
- 2.79 cm
- 11.3 cm
- 230 g
- 90 days warranty
- Designed For
- HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL2024 Ultrium 3000, MSL2024 Ultrium 3280, MSL2024 Ultrium 920, MSL4048 Ultrium 1760, MSL4048 Ultrium 1840, MSL4048 Ultrium 3000, MSL4048 Ultrium 3280, T950 3 Drive Bay Assembly Expansion Frame, T950 6 Drive Bay assembly, T950 6 Drive Bay Assembly Expansion Frame, T950 LTO Media Expansion Frame , HPE LTO-5 Ultrium 3000 , HPE StorageWorks ESL9322, ESL9595L1, MSL2024, MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL2024 Ultrium 3000, MSL2024 Ultrium 3280, MSL2024 Ultrium 448, MSL2024 Ultrium 920, MSL2024 Ultrium 960, MSL4048, MSL4048 Ultrium 1760, MSL4048 Ultrium 1840, MSL4048 Ultrium 3000, MSL4048 Ultrium 3280, MSL4048 Ultrium 448, MSL4048 Ultrium 920, MSL4048 Ultrium 960, MSL6000 Ultrium 1840, MSL6030, MSL6030 Ultrium 1840, MSL6030 Ultrium 460, MSL6030 Ultrium 960, MSL6060 Ultrium 1840, MSL6060 Ultrium 460, MSL6060 Ultrium 960, MSL8096 Ultrium 1840, MSL8096 Ultrium 920, MSL8096 Ultrium 960, SAS Rack-Mount Kit, SB1760c Tape Blade , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 448, Ultrium 920 , HPE StorageWorks 1/8 Tape Autoloader Ultrium 230, Ultrium 460 , HPE StorageWorks Ultrium 232, 232 Trade-Ready, 448, 448 Array Module, 460, 920, 960 , HPE StoreEver MSL2024 Ultrium 15000, MSL2024 Ultrium 3000, MSL2024 Ultrium 6250, MSL3040 Scalable Library Base Module, MSL3040 Scalable Library Expansion Module, MSL4048, MSL4048 LTO-5 Ultrium 3000, MSL4048 Ultrium 15000, MSL4048 Ultrium 3000, MSL4048 Ultrium 6250, MSL6480 Scalable Base Module, MSL6480 Scalable Expansion Module , HPE SureStore Ultrium , HPE Ultrium 448, 920
HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge | In Stock | £35.59 |
HPE Ultrium Data Cart LTO 5 | In Stock | £25.83 |
HPE Ultrium RW Data Cartridge LTO Ultrium 7 6TB 15TB | In Stock | £55.76 |
