HPE Ultrium 920 SAS Internal Tape
Quicklinx: 54T1WS00 Mfr#: EH847A
The HP StorageWorks Ultrium 920 Tape Drive is the highest capacity, fastest performance half-height tape drive in the StorageWorks family based on HP's third generation LTO technology. The Ultrium 920 delivers a compressed storage capacity of 800 GB per data cartridge and a compressed data transfer rate of 432 GB per hour, two and a half times faster than the previous generation Ultrium 448 tape drive. Multiple drive models are available for the compact, half-height Ultrium 920 Tape Drive including internal, external, and 1U rack-mount model. The Ultrium 920 Tape Drive is fully read and write compatible with all second-generation Ultrium media and offers further investment protection through its backward-read compatibility with first-generation Ultrium media.
HPE StorageWorks Ultrium 920 - tape drive - LTO Ultrium - SAS
Tape drive
Recording Standard
LTO Ultrium 3
Enclosure Type
Internal
Interface Type
SAS
14.5 cm x 20.6 cm x 4.1 cm
1.5 kg
Carbonite
Storage Removable
LTO Ultrium - 5.25" x 1/2H
Storage Removable Capacity
400 GB (native) / 800 GB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 2, Ultrium 3
Data Transfer Rate (native)
60 MBps (216 GBph)
Data Transfer Rate (compressed)
120 MBps (432 GBph)
IBM AIX, SunSoft Solaris, HP-UX, Novell NetWare, Red Hat Linux, Microsoft Windows, UnitedLinux
Microsoft Certification
Compatible with Windows 7
3-year warranty
ProLiant DL120 G7, DL165 G5, DL165 G7, DL180 G5, DL185 G5, DL320 G5p, DL360 G5, DL365, DL365 G5, DL370 G6, DL380 G6, DL385 G2, DL385 G5, DL785 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G6, ML330 G6, ML350 G5, ML350 G6, ML370 G6; StorageWorks Rack-Mount Kit Ultrium 1760
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 3
Enclosure Type
Internal
Interface Type
SAS
Enclosure Colour
Carbonite
14.5 cm
20.6 cm
4.1 cm
1.5 kg
Storage Removable
Recording Standard
60 MBps (216 GBph)
120 MBps (432 GBph)
Average Seek / Access Time
64 sec
Buffer Size
64 MB
1 x SAS
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
1 x SAS cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15
Software Included
Drivers & Utilities, HP StorageWorks Library and Tape Tools, HP StorageWorks Data Protector Express Single Server
Limited warranty - parts - 3 years - response time: next day , Technical support - phone consulting - 3 years
10 °C
20 - 80%
HPE ProLiant DL120 G7, DL165 G5 Special Server, DL165 G7 Base, DL165 G7 Performance, DL180 G5 Special Server, DL185 G5 Special Server, DL320 G5p, DL360 G5, DL360 G5 Entry, DL360 G5 Performance, DL365 Base, DL365 Entry, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5 Entry, DL785 G5, ML110 G6, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML115 G5, ML150 G6, ML150 G6 Base, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive
54T1 HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
