HPE U320e SCSI Dual Bus Adapter
Quicklinx: 52BNWS00 Mfr#: AH627A
The HP StorageWorks U320e SCSI Host Bus Adapter provides customers with the flexibility and speed they have come to expect from HP. This HBA is ideal for HP MSL Tape Library customers needing to attach to ProLiant servers using the PCI-Express interface, and provides support for Ultra320 SCSI, Wide Ultra3 SCSI, and Wide Ultra2 SCSI protocols. It is the primary building block for SCSI backup solutions that provide the maximum of 320 MB/second bandwidth, twice the speed of previous-generation SCSI adapters.
HPE StorageWorks U320e SCSI Host Bus Adapter - storage controller - Ultra320 SCSI - PCIe x4
Storage controller - plug-in card
Bus Type
PCIe x4
Ultra320 SCSI
Data Transfer Rate
320 MBps
Supported Devices
Tape drive
Microsoft Windows Server 2003, Red Hat Enterprise Linux ES 3, SuSE Linux Enterprise Server 9, Red Hat Enterprise Linux ES 4, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 x64 Edition
16.8 cm x 6.9 cm
1-year warranty
ProLiant DL120 G7, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL580 G5, DL580 G7, DL980 G7, ML110 G7, SL160s G6; StorageWorks Network Storage Gateway X3400 G2, X3800 G2; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2; StorageWorks Rack-Mount Kit Ultrium 920
Host Bus
PCIe x4
Storage Controller
Ultra320 SCSI
Data Transfer Rate
320 MBps
Supported Devices
Tape drive
2 x Ultra320 SCSI (LVD) - 68 PIN VHDCI (external)
Compatible Slots
1 x PCI Express x4
Low-profile bracket
Limited warranty - parts - 1 year
16.8 cm
6.9 cm
HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL165 G5 Special Server, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G6, DL180 G6 Special Server, DL185 G5 Special Server, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL980 G7, ML110 G6, ML110 G7, ML150 G6, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL165z G7, SL170z G6, SL2x170z G6 , HPE StorageWorks MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760, MSL4048 Ultrium 1840, MSL8096 Ultrium 1840 , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 1760, Ultrium 920 , HPE StorageWorks Network Storage Gateway X3400 G2, X3800 G2 , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2 , HPE StorageWorks Rack-Mount Kit Ultrium 920 Drive , HPE StorageWorks Ultrium 1760
