Looking for cost-effective power protection for your small office environments? HP Line Interactive Single Phase Uninterruptible Power System (UPS) solutions range from tower-based systems designed to safeguard tower servers and small office equipment, to rack-based systems that can protect a full rack of servers. Standard features include intuitive front panel displays for local management, hot-swappable battery modules, and HP Enhance Battery Management (EBM) that help to extend the service-life of your batteries. HP Power Protection, a power management software application that ships with each model, combined with a UPS Network Module, optional on some models, enables you to remotely monitor and manage your UPS through HP Systems Insight Manager or via a standard web browser. Backed by a 3-year limited warranty, HP's exclusive 30-day Battery Pre-Failure Warning provides notification of an impending battery failure and free battery replacement while under the warranty.
Tower UPS Models Provide Power Protection and Management Optimized for Smaller IT Environments
HP Line Interactive Single Phase Uninterruptible Power System Tower models lower your power protection cost by providing up to eight (8) power outlets per UPS, allowing you to safeguard your IT and office equipment.Standard features include an intuitive front panel display, Enhanced Battery Management (EBM), Network Transient Protection, and serial and USB ports for data exchange with the host computer.Support hot-swappable battery packs that allow you to safely install a new battery without ever powering down connected computer equipment.Includes (at no additional cost) HP Power Manager software that provides the flexibility to monitor power conditions and control the HP UPS locally or remotely.Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty. -
Flexible Rack/Tower Models Deliver Cost-Effective Power Protection Inside and Outside of the IT Rack
HP Line Interactive Single Phase Uninterruptible Power System Rack/Tower (R/T) models can be used in a traditional rackmount environment or converted to a tower UPS to support tower servers and other equipment outside of an IT rack.Support up to four (4) Extended Runtime Modules (ERM) to increase battery run time during a power outage.Standard features include an enhanced front panel display, HP Enhanced Battery Management (EBM) to easily manage and extend the service life of your batteries, and hot-swappable batteries that can be serviced while the UPS is in operation.HP Power Protection software (included) and an UPS Network Module (optional) enable you to monitor and manage power through HP Systems Insight Manager and other SNMP management programs or via a standard web browser.Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty. -
Ultra-Dense Rack UPS Models Scale from Small to Enterprise IT Environments
HP Line Interactive Single Phase Uninterruptible Power System Rackmount models provide from 1.5kVA (R1500 G4) up to 7.2kVA (R7000) of output power in as little as 4U of rack space.Support up to four (4) Extended Runtime Modules (ERM) to increase battery run time during a power outage (R5000 and R7000 only).Support hot-swappable battery packs that allow you to safely install a new battery without ever powering down connected computer equipment.The R5000 and R7000 include both HP Power Protection software and an UPS Network Module that enable you to monitor and manage power through HP Systems Insight Manager and other SNMP management programs or via a standard web browser (UPS Network Module optional on R1500 G4).Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty.
- HPE UPS T1000 G3 - UPS - 1000 VA
- UPS - external
- 12.7 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- + 6% / - 10%
- Power Capacity
- 1000 VA
- Input Connectors
- 1 x power IEC 60320 C13
- Output connectors
- 6 x power IEC 60320 C14
- Battery
- Lead Acid
- Run Time (Up To)
- 5 min at full load
- 15 cm x 33.3 cm x 19.3 cm
- 3-year warranty
- Designed For
- ProLiant DL165 G7, DL320 G5p, MicroServer, MicroServer Gen8, ML110 G5, ML110 G6, ML110 G7, ML115 G5, ML150 G5, ML150 G6, ML310 G5, ML310 G5p, ML310e Gen8, ML330 G6, ML350 G6, ML350e Gen8, ML350p Gen8
- UPS - external
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- + 6% / - 10%
- Power Capacity
- 1000 VA
- Output Waveform
- Sinewave
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 24 hours
- 1 x management (USB) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
- Cables Included
- USB cable - external - 1.8 m , Serial cable - external - 1.8 m
- Equipment Protection Value
- 250000 US Dollars
- LED display, audible alarm
- UL, VCCI, C-Tick, GOST, GS, NOM, EK, FCC, RoHS, ICES, S Mark
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95%
- Sound Emission
- 45 dBA
- 15 cm
- 33.3 cm
- 19.3 cm
- 12.7 kg
- Designed For
- HPE ProLiant DL165 G7, DL165 G7 Base, DL165 G7 Special Server, DL320 G5p, MicroServer, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Base Starter Kit, MicroServer Gen8 Entry, ML110 G5, ML110 G6, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML115 G5, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML150 G5 Special Server, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G5, ML310 G5p, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350p Gen8
