The HPE StoreEver 1/8 G2 Tape Autoloader provides cost-effective, easy-to-install, unattended automated tape storage ideal for archiving and for entry-level or remote office automated data backup. The autoloader combines incredible storage density and features into a compact 1U form factor. Capable of up to 120 TB of compressed capacity in only a 1U form factor, the autoloader is well equipped to offer solutions for data growth. Web-based remote management offers the capability to quickly and easily access, configure, monitor, and troubleshoot the autoloader that will reduce dependencies on local IT staff while allowing multiple sites to be supported centrally. Protect confidential business information with native encryption, ensuring that if a tape is lost or stolen your data is protected from unauthorized access. Proactively monitor utilization, operational performance, as well as life and health information for both the drive and media with HPE TapeAssure.
Exceptional Storage Density
Up to 120 TB of compressed capacity in only a 1U form factor using an LTO-7 Ultrium 15000 tape drive, which is more than double the capacity of LTO-6 tape autoloaders. Up to 300 MB/s native throughput, which is 180% faster than the LTO-6 tape autoloaders. Long term data archiving with a specified 30 year media shelf life in normal ambient conditions.
Easy to Manage and Use
LTFS provides a self-describing file system on a HPE LTO-7 cartridge, which enables the combined archiving benefits of application independence, transportability and protection from obsolescence. HPE StoreOpen Automation is a free downloadable application that extends the LTFS capability to HP Autoloaders, HPE MSL and ESL Tape Libraries. Each autoloader includes one mail slot, two removable 4-slot magazines for bulk loading of media, and a convenient bulk storage unit for moving media offsite. The bar code reader provides faster inventory times and facilitates tracking of media. Access, configure, monitor, and troubleshoot the 1/8 G2 Tape Autoloader with the web-based remote management feature reducing the need for remote office IT staff.
Full Featured
Proactively monitor drive and media utilization, operational performance, life and health information for drive and media with TapeAssure. Offers high level encryption capability with the HP 1/8 G2 Encryption Kit. It is quickly installed into an LTO-6, LTO-5 or LTO-4 Ultrium autoloader and maintains up to 100 encryption keys ensuring data privacy to secure confidential business information for tape cartridges located on or off site.
Up to 240TB of compressed capacity in only a 1U form factor using an LTO-8 Ultrium 30750 tape drive, which is double the capacity of LTO-7 Tape Autoloaders.Up to 300 MB/s native throughput.Long term data archiving with a specified 30 year media shelf life in normal ambient conditions. -
LTFS provides a self-describing file system on a HPE LTO-8 cartridge, which enables the combined archiving benefits of application independence, transportability and protection from obsolescence.HPE StoreOpen Standalone is a free downloadable application that extends the LTFS capability to HPE 1/8 G2 Autoloaders.Each autoloader includes one mail slot, two removable 4-slot magazines for bulk loading of media, and a convenient bulk storage unit for moving media offsite.The bar code reader provides faster inventory times and facilitates tracking of media.Access, configure, monitor, and troubleshoot the 1/8 G2 Tape Autoloader with the web-based remote management feature reducing the need for remote office IT staff. -
Additional features with software downloads and licenses
Download CVTL for free to manage, monitor and configure multiple tape libraries through a single console.Proactively monitor drive and media utilization, operational performance, life and health information for drive and media with TapeAssure Advanced.Offers high level encryption capability with the HPE 1/8 G2 Encryption Kit. It is quickly installed into an LTO-8, LTO-7, LTO-6 or LTO-5 Ultrium Autoloader and maintains up to 100 encryption keys ensuring data privacy to secure confidential information for tape cartridges located on or off site.
- HPE StoreEver 1/8 G2 Ultrium 15000 - tape autoloader - LTO Ultrium - 8Gb Fibre Channel
- Tape autoloader
- Recording Standard
- LTO Ultrium 7
- Enclosure Type
- External - 1U
- Interface Type
- 8Gb Fibre Channel
- Total Storage Capacity
- 48 TB (native) / 120 TB (compressed)
- Removable Media Capacity
- 8
- Average Media Exchange Time
- 34 sec
- Supported Tape Drives
- LTO Ultrium 7
- Key Features
- Barcode reader, encryption
- 48.2 cm x 80.9 cm x 4.4 cm
- 11.5 kg
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 6 TB (native) / 15 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 6, Ultrium 7
- Data Transfer Rate (native)
- 300 MBps (1.08 TBph)
- Data Transfer Rate (compressed)
- 750 MBps (2.7 TBph)
- Power
- AC 120/230 V (50/60 Hz)
- Manufacturer Selling Program
- HP Top Value Lite
- 1-year warranty
- Tape autoloader - LTO Ultrium
- LTO Ultrium 7
- Enclosure Type
- External - 1U
- Interface Type
- 8Gb Fibre Channel
- 8
- 34 sec
- LTO Ultrium 7
- Key Features
- Built-in Devices
- Led panel
- 48.2 cm
- 80.9 cm
- 4.4 cm
- 11.5 kg
Storage Removable
- LTO Ultrium
- Capacity
- Buffer Size
- 1024 MB
- 1 x 8Gb Fibre Channel , 1 x (management) - RJ-45 , 1 x USB (management)
- Media Included Qty
- 8
- Included Accessories
- 6 rubber feet
- Cables Included
- 1 x network cable , 1 x Fibre Channel cable
- Rack Mounting Kit
- Optional
- MTBF
- 100,000 hour(s)
- MSBF
- 2,000,000
- HP Top Value Lite
- Power supply
- Voltage Required
- 80 Watt
- Limited warranty - parts - 1 year
- 5 °C
- 40 °C
- 10 - 80% (non-condensing)
HPE LTO-6 Ultrium 6.25TB RW Data Tape | In Stock | £25.75 |
