HPE 2GB PC3-10600 2GB DDR3 1333MHz memory module2GB DDR3, 240-pin DIMM, 1333MHz, Unbuffered
Internal memory: 2 GB
Internal memory type: DDR3
Memory clock speed: 1333 MHz
Component for: PC/server
Memory form factor: 240-pin DIMM
CAS latency: 9
Module configuration: 128M x 8
- HP - DDR3 - module - 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9
- Unbuffered
- Designed For
- HP 505B
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9
- Non-ECC
- Unbuffered
- Chips Organization
- 128 x 8
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HP 505B
