HPE SN3000 SStarter Kit Switch Managed 12x16Gb Fibre Channel SFP+ - Rack-Mountable (pack of 2)
Quicklinx: CLBCWS00 Mfr#: H0HP1A
Type: Fibre Channel
Ports: 12
Managed: Yes
£7,040.00 ex VAT
£8,448.00 inc VAT
To remain competitive, IT organizations must keep pace with ever-increasing workloads without a similar increase in their budgets or resources. While virtualization has provided some relief by enabling the benefits of faster deployment and consolidation, it tends to put additional stress on data center networks. The HP SN3000B 16Gb Fibre Channel Switch meets the needs of hyper-scale, private cloud storage environments by delivering market-leading 16Gb Fibre Channel technology and capabilities that support highly virtualized environments. Designed to enable maximum flexibility and investment protection, the SN3000B switch scales from 12 to 24 ports and supports 4, 8, or 16 Gb/s speeds in an efficiently designed 1U package. It also provides a simplified deployment process and a point-and-click user interface making it powerful and easy to use. It offers low-cost access to SAN technology while providing "pay-as-you-grow" scalability to meet the needs of an evolving storage environment.
  • Flexible Fabrics
    High speed 16Gb optimized inter switch links (ISLs) provide twice the performance as previous generation Fibre Channel switches. The net result is there are fewer links, fewer cables, fewer ports and less power for the same performance.
  • High Performing
    Operating speeds of 16, 8, and 4 Gb/s offer a wide range of performance for flexibility in connectivity options and investment protection.
  • Operational Simplicity
    Diagnostic Ports (D_Ports) are a new port type that enable administrators to identify and isolate optics and cable problems, reducing fabric deployment and diagnostic times. Organizations also can use D_Ports to run a variety of tests for ports, SFPs, and cables for faults, latency, and distance.SAN Network Advisor, offered as an option, provides comprehensive management of data center SAN fabrics, including configuration, monitoring, diagnostics, best-practices validation, and management of B-series Directors, Switches, and Host Bus Adapters (HBAs).
  • Cloud Optimized Performance
    Provides aggregate 768Gb full-duplex throughput and any eight ports can be trunked for 128Gb Inter-Switch Links (ISLs). Exchange-based Dynamic Path Selection (DPS) optimizes fabric-wide performance and load balancing by automatically routing data to the most efficient available path.
HPE SN3000 - Starter Kit - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - Managed
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Back to front airflow rack-mountable 1U
Subtype
Fibre Channel
Ports
12 x 16Gb Fibre Channel SFP+
Performance
Fabric latency: 700 ns
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, SMI-S, SSH-2
ISL support, Syslog support, firmware upgradable
Power Redundancy
Optional
43.8 cm x 44.3 cm x 4.3 cm
7.82 kg
Packaged Quantity
Enclosure Type
Subtype
Fibre Channel
Ports
Performance
Authentication Method
RADIUS, Secure Shell v.2 (SSH2), LDAP
1 x management (LAN) RJ-45 , 1 x serial RJ-45 management , 1 x USB Type A , 12 x 16Gb Fibre Channel SFP+ , 12 x 16Gb Fibre Channel SFP+ Ports on Demand
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
PCI-e SN1100E Dual Port 16Gb FC HBA, 4 x 16Gb Fibre Channel SFP+ Short Wave Transceiver
1 x serial cable , 4 x fibre optic cable - 5 m
Rack Mounting Kit
Included
Software Included
Brocade Advanced Zoning, Brocade Advanced Web Tools, HP SAN Network Advisor Professional, Brocade EZ Switch
43.8 cm
44.3 cm
4.3 cm
7.82 kg
10 - 85% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Type: Fibre Channel
Ports: 12
Managed: Yes
Brand: HPE
Price Range Ex VAT: £1500+
