HPE Smart Array P410/P411 512MB BBWC Module Upgrade KT
Quicklinx: 6434WS00 Mfr#: 462967-B21
HPE BBWC Upgrade - DDR2 - 512 MB
Capacity: 512 MB
Upgrade Type: System specific
Designed For: HPE ProLiant BL460c G7, BL620C G7, BL680c G7, DL160 G6, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL180 G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL370 G6 Base, DL370 G6 High Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, ML110 G7, ML150 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, WS460c G6 Workstation Blade HP Smart Array P410/256MB Controller, P411/256MB Controller HP StorageWorks Disk Enclosure D2600, D2700 HP StorageWorks Modular Disk System 600 HP StorageWorks Network Storage Gateway X3400 G2, X3800 G2 HP StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
HPE BBWC Upgrade - DDR2 - module - 512 MB
Memory module
512 MB
Memory Type
DDR2 SDRAM
Upgrade Type
System specific
ProLiant BL460c G7, BL620C G7, BL680c G7, DL165 G7, DL360 G7, DL370 G6, DL380 G7, DL385 G7, DL580 G7, DL585 G7, ML110 G7, ML350 G6, WS460c G6; StorageWorks Network Storage Gateway X3400 G2, X3800 G2; StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
512 MB
Upgrade Type
System specific
DRAM memory module
DDR2 SDRAM
Compatible Slots
1 x memory
HPE ProLiant BL460c G7, BL620C G7, BL680c G7, DL160 G6, DL160 G6 Special Server, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 Base, DL370 G6 High Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, ML110 G7, ML150 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, WS460c G6 Workstation , HPE Smart Array P410/256MB Controller, P411/256MB Controller , HPE StorageWorks Disk Enclosure D2600, D2700 , HPE StorageWorks Modular Disk System 600, 600 with two Dual Port I/O Module System , HPE StorageWorks Network Storage Gateway X3400 G2, X3800 G2 , HPE StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
