HPE Slim 12.7mm SATA DVDRW Optical
Quicklinx: 5KVGWS00 Mfr#: 481043-B21
The DVD RW drive is capable of reading DVD 4.7 GB through 8.5 GB media. It can also read standard stamped, CD-R, and CD-RW media. This drive supports writing to CD-R, CD-RW, DVD +R/RW, and DVD -R/RW media via software utilities. For Microsoft operating systems, this is available by installing the included Roxio software disk. For other operating systems, an operating system-specific software utility is required for writing to media. The DVD-ROM drive is designed to read not only CD-ROM and CD -R/RW discs but also DVD-ROM, DVD-RAM, DVD +R/RW and DVD -R/RW discs.
  • Typical Customers are Those Who
    Want to perform local back up or retail/branch office configuration archiving.Want to locally install software/patches or load data.Require an OS boot disk that is larger than traditional floppy drives.Need the latest in optical drive support with DVD capacity.
HPE DVD±RW drive - Serial ATA - internal
DVD±RW drive - internal
Serial ATA
13.2 cm x 13.8 cm x 1.3 cm
Optical Storage
DVD±RW - 5.25" x 1/6H (Slim Line)
Read Speed
24x (CD) / 8x (DVD)
Media Load Type
Tray
ProLiant DL120 G5, DL180 G5, DL180 G6, DL320 G5p, DL370 G6, DL380 G6, DL380 G7, DL385 G5p, DL385 G6, DL385 G7, DL580 G5, DL580 G7, DL585 G7, DL980 G7, ML370 G6
Serial ATA
13.2 cm
13.8 cm
1.3 cm
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, Photo CD
Supported Media Types
CD-R, CD-RW, DVD-R, DVD+R
Media Load Type
Tray
Access Time
120 ms (DVD), 110 ms (CD)
Buffer Size
2 MB
Horizontal/vertical mountable
Hard Drive
Interface Type
SATA 1.5Gb/s
1 x Serial ATA-150
Compatible Bay
1 x 5.25" x 1/6H (Slim Line) - front accessible
1 x Serial ATA cable
MTBF
60,000 hour(s)
Limited warranty - parts - 1 year
5 °C
50 °C
HPE ProLiant DL120 G5, DL180 G5, DL180 G5 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G5p, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G6 ICE Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL980 G7, ML370 G6, ML370 G6 Base, ML370 G6 Entry
