HPE RDX Removable Disk Backup System
Quicklinx: BLDVWS00 Mfr#: C8S07B
Type: Disk drive
Hurry, only 1 left in stock!
£85.34 ex VAT
£102.40 inc VAT
Express delivery Order within the next 17 hours for delivery on Monday
HPE RDX Removable Disk Backup System is a rugged, removable, easy-to-use, cost effective, disk backup solution for servers and workstations. It is the ideal backup solution for remote locations or small to medium businesses with little or no IT resources that are in less than ideal locations such as a busy office, field base sites, or business that require mobility. The new HPE RDX+ is perfect for these environments due to its ruggedness and the fact that it only requires a USB connection, no separate power source/cord required. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station. The HPE RDX Removable Disk Backup System offers fast disk-based performance with the ability to store 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360 GB/hr.
  • Backup and Recovery Made Easy
    The HPE RDX Removable Disk Backup System delivers a rugged, portable cartridge design protecting hard drive information and making transporting data between locations easy and more recoverable. Add a disaster recovery strategy to your business by simply rotating cartridges off site. off-site.Complement your cloud storage and implement best practices with a local backup copy that allows you faster access to critical data whenever you need it. Protecting your information both on- and off-premises.Delivering hard drive data transfer speeds and built in anti-vibration buffers, to increase read/write speeds, lowering the time it takes for incremental or full backups. This leaves you free to concentrate on running your business.As backup needs grow, you can easily and affordably expand your system by simply adding more cartridges - no new is hardware required. The HPE RDX Removable Disk Backup System supports disk spanning so data can bridge multiple cartridges.Compatibility across various operating systems and virtualization platforms makes it simple to adapt into any small business environment. You can also use Fixed Disk mode for automated backups via the native Microsoft Windows operating system.
  • Unmatched Portability
    Low-power ruggedized design offers flexibility to plug it in anywhere and feel confident the data is always available and safe.Cartridge style hard drive has a 97 percent survival rate compared to 0 percent for ordinary USB drives in a independent drop test.Built in static protection eliminates server or workstation failures due to statically charged peripherals.
  • Fast Backup and Recovery
    Ability to recover quickly with disk to disk backup performance reaching speeds of up to 360 GB/hr.Supports drag and drop file access making backup as simple and convenient as the click of the mouse.No need to worry about backups being larger than disk space, with disk spanning just add cartridges during the backup process, dynamically increasing the backup.Inner buffers built into the system lower disk drive vibration, increasing read/write disk performance.
  • Easy Integration
    HPE qualified and tested, making it easy to integrate into your server storage and networking environments.With fixed disk mode capability, RDX easily integrates into multiple small business operating system environments.Internal dock option makes it easy to configure with ProLiant and StoreEver products.
HPE RDX Removable Disk Backup System - RDX drive - SuperSpeed USB 3.0 - external
RDX drive - external
SuperSpeed USB 3.0
10.98 cm x 17.75 cm x 5.18 cm
540 g
Storage Removable
RDX cartridge
Media Type
RDX cartridge
Data Transfer Rate
600 MBps (external) / 100 MBps (internal)
ProLiant MicroServer Gen10 Entry
SuperSpeed USB 3.0
10.98 cm
17.75 cm
5.18 cm
540 g
Storage Removable
RDX cartridge
Media Type
RDX cartridge
Data Transfer Rate
Average Seek / Access Time
12 ms
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable
MTBF
550,000 hours
VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, UL 60950, CISPR 22, FCC
6.6 Watt
Software Included
Drivers & Utilities
Linux, Microsoft Windows
5 °C
45 °C
20 - 80% (non-condensing)
HPE ProLiant MicroServer Gen10 Entry
Type: Disk drive
Brand: HPE
Stock Status: While stocks last
Stock Status: Clearance
