HPE R110 Wireless 11n VPN WW Router
Quicklinx: BGMKWS00 Mfr#: J9975A
  • IEEE 802.11n
£131.11 ex VAT
£157.33 inc VAT
The HP R100 Router Series is an ideal all-in-one solution for small businesses. Part of the HP OfficeConnect portfolio, the routers delivers high-performance Internet access with both wired, wireless connectivity for remote offices and employees. Featuring the next generation HP Networking user interface with an Easy Setup Wizard, they are designed for simplicity and reliability to get your business connected quickly, while robust security features safeguard your organization. The routers feature a compact executive design for unobtrusive use in office environments.
  • Keep Small Business Users Connected and Productive
    The HP R100 Router Series is an ideal all-in-one solution for small businesses that includes high-speed networking with a built-in, 4-port Gigabit Ethernet switch to make certain your organization has fast access to the data and files needed to get their jobs done.Employees can stay productive while moving throughout the office with a choice of integrated IEEE 802.11n or 802.11ac wireless technology. The router series offers a choice of single radio dual band or dual radio device with 3x3 MIMO antennas that support high speeds at 5GHz and 2.4GHz.Advanced Quality of Service (QoS) helps assure time-sensitive traffic is prioritized for reliable delivery.Delivers excellent business productivity with reliable Internet connectivity with Gigabit Ethernet WAN interface for high-performance connectivity to the Internet, remote workers and locations.
  • Protects Your Organization from Unauthorized Access
    The HP R100 Router Series features a Stateful Packet Inspection Firewall combined with features like WPA/WPA2 encryption, 802.1X, URL filter, Content Filters and Trusted Users Management to keep your network safe from outside threats and unauthorized access.The series offers mobile workers and offices connectivity over the public Internet through a virtual private network (VPN), complete with enterprise-grade encryption and authentication for security.With comprehensive time-based rules, the router series can be set to automatically connect and disconnect features such as the wireless radios, URL filters, and content filters to restrict access to specific times of day.
  • Easy To Use and Manage
    The HP R100 Router Series introduces the next generation HP Networking Web interface design with intuitive configuration tasks, troubleshooting tools and proactive monitoring in a clean, user-friendly layout.An Easy Setup Wizard allows users to quickly setup your network and connect your organization.Features like email alerts, logs, Alert LED helps proactively notify users of attacks and anomalies in the network to ensure quick resolution with minimum downtime.
  • Flexibility that Fits Your Business
    The HP R100 Router Series is future-ready with IPv6 support.The sleek, unobtrusive design with internal wireless antennas fits well in any setting.The Wireless Distribution System (WDS) feature allows you to scale your wireless network as your organization grows. It provides an extremely flexible and cost-effective way to link or extend wireless connectivity.
HPE R110 WW - wireless router - Wi-Fi - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput: up to 30 Mbps , NAT throughput: 920 Mbps
IPSec VPN tunnels: 5 , Concurrent sessions: 5 , Virtual interfaces (VLANs): 4
Network / Transport Protocol
PPTP, L2TP, IPSec, ARP, DHCP, DDNS
Routing Protocol
RIP-1, RIP-2, IGMP, static IPv4 routing, static IPv6 routing, RIPng, MLD
Remote Management Protocol
SNMP 1, SNMP 2c, HTTPS
DHCP support, NAT support, VPN support, PAT support, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, content filtering, MAC address filtering, IPv6 support, VPN passthrough, WDS support, URL filtering, IP address filtering, firmware upgradable, MIMO technology, STP support, WMM support, QoS, IPSec NAT-T, WPS, DHCP server, Samba support, FTP server, Multiple SSID support, MLD snooping, fanless, SPIF, NAC, NTP time synchronisation, MLD, CoS, DoS
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
21.59 cm x 13.97 cm x 3.81 cm
450 g
3-year warranty
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
MAC Address Table Size
2048 entries
Routing Protocol
Encryption Algorithm
WPA, WPA2
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, EN55022 Class B, ICES-003 Class B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, FCC Part 15, UL 60950-1, EN 60950-1, FCC Part 15.407, EN 60601-1-2, EN 62311, EN 300 328, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
1 x MIPS 700 MHz
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
External power adapter
9.5 Watt
MTBF
51.54 years
21.59 cm
13.97 cm
3.81 cm
450 g
Limited warranty - advance parts replacement - 3 years - response time: next business day
5 - 95% (non-condensing)
Accessories (2)
Get the most from your Router
BGMK HPE HP X120 SFP (mini-GBIC) Transceiver Module In Stock £166.29
BGMK HPE X120 1G SFP LC LX Transceiver In Stock £355.96
Other bundles (3)
BGMK C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
BGMK C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.75
BGMK C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Type: Wireless router
Standards: IEEE 802.11b
Standards: Gigabit Ethernet
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Brand: HPE
