Looking for cost-effective power protection for your small office environments? HP Line Interactive Single Phase Uninterruptible Power System (UPS) solutions range from tower-based systems designed to safeguard tower servers and small office equipment, to rack-based systems that can protect a full rack of servers. Standard features include intuitive front panel displays for local management, hot-swappable battery modules, and HP Enhance Battery Management (EBM) that help to extend the service-life of your batteries. HP Power Protection, a power management software application that ships with each model, combined with a UPS Network Module, optional on some models, enables you to remotely monitor and manage your UPS through HP Systems Insight Manager or via a standard web browser. Backed by a 3-year limited warranty, HP's exclusive 30-day Battery Pre-Failure Warning provides notification of an impending battery failure and free battery replacement while under the warranty.
Ultra-Dense Rack UPS Models Scale from Small to Enterprise IT Environments
HPE Line Interactive Single Phase Uninterruptible Power System Rackmount models provide from 1.5kVA (R1500 G4) up to 7.2kVA (R7000) of output power in as little as 4U of rack space.The R5000 and R7000 include both HPE Power Protection software and an UPS Network Module that enable you to monitor and manage power through HPE Systems Insight Manager and other SNMP management programs or via a standard web browser (UPS Network Module optional on R1500 G4).Includes a front panel LCD display.Enhanced system flexibility with two independently controlled load segments.
- HPE R/T3000 G4 High Voltage - UPS - 2700 Watt - 3000 VA
- UPS - rack-mountable / external
- Rack Size
- 2U
- 39.54 kg
- Input Voltage
- AC 200/230/208-240 V
- Power Capacity
- 2700 Watt / 3000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13 , 1 x power IEC 60320 C19 16A
- Battery
- Lead Acid expandable
- Batteries Qty
- 1 (installed) / 5 (supported)
- Run Time (Up To)
- 5 min at full load
- Networking
- RS-232, USB
- Included Accessories
- Rack mounting rails, floor stand
- 44.1 cm x 64.7 cm x 8.62 cm
- 3-year warranty
- Designed For
- ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, DL580 Gen8, DL580 Gen9, DL60 Gen9, DL80 Gen9, MicroServer Gen8, ML10, ML10 v2, ML110 Gen9, ML150 Gen9, ML310e Gen8, ML350e Gen8
- Height (Rack Units)
- 2U
- Input Voltage
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Power Capacity
- Output Waveform
- Sinewave
- Circuit Protection
- Circuit breaker
- Efficiency
- 94%
- Expandable
- Quantity
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Run Time (Up To)
- 45 min at 20% load , 15 min at half load , 7 min at 80% load , 5 min at full load
- Recharge Time
- 48 hours
- Maintenance free, sealed
- Remote Management Interface
- RS-232, USB
- 1 x USB , 1 x RS-232 - 9 pin D-Sub (DB-9)
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Cables Included
- USB cable , Serial cable
- Rack Mounting Kit
- Included
- Equipment Protection Value
- 250000 US Dollars
- LCD display, Remote Emergency Power Off (REPO)
- UL, TUV, VCCI, C-Tick, cUL, EN 60950, GS, UL 1778, IEC 62040-1-1, UL 60950-1, IEC 60950-1, WEEE, EN 62040-1-1, CSA C22.2 No. 107.3, EAC, EN 62040-1
- Software Included
- HP Power Protector (free download)
- Limited warranty - parts and labour - 1 year , Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
- 44.1 cm
- 64.7 cm
- 8.62 cm
- 39.54 kg
- Shipping Width
- 59 cm
- Shipping Depth
- 92.1 cm
- Shipping Height
- 28 cm
- Shipping Weight
- 48.75 kg
- Designed For
- HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL320e Gen8 Special Server, DL320e Gen8 v2, DL320e Gen8 v2 Base, DL320e Gen8 v2 Entry, DL320e Gen8 v2 Performance, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8 Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL580 Gen8, DL580 Gen8 Base, DL580 Gen8 High Performance, DL580 Gen9, DL580 Gen9 Base, DL580 Gen9 High Performance, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Entry, MicroServer Gen8 Performance, ML10, ML10 Entry, ML10 Special, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML310e Gen8, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350e Gen8 v2 Entry
