HPE ProLiantDL580 Gen7 Intel Xeon E7-4870 128GB (16x8GB) NO HDD
Quicklinx: 9NRYWS00 Mfr#: 696729-421
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-ROM
Traditionally, mission-critical RAS (Reliability, Availability and Serviceability) features have been associated with RISC (Reduced Instruction Set Computing) systems. HP has designed an eco-system of RAS functionalities that has raised the bar for the HP ProLiant DL580 G7 Server series. The DL580 G7 continues to deliver best-in-class HP performance, manageability, and reliability features with the latest Intel processor technology and it is the ideal choice for customers that are ready to deploy large databases that require scale-up compute processing, large memory and I/O intensive applications.
  • Outstanding Performance and Scalability
    Flexible technologies provides customer choice in networking with either a Broadcom or Qlogic solution.I/O expansion capabilities, the latest 10 core Intel processors, expandable DDR3 memory enables growing scaling up IT infrastructure as the business grows.The HP 4S architecture, new memory landscape of 2TB, 10Gb NIC upgrade option, up to 11 I/O slots and industry leading management solutions make this system ideal for virtualization.High performing Intel Xeon processor E7-4800 and 7500 series, faster memory access, higher network and I/O bandwidths enables the DL580 G7 for critical applications and workloads.
  • Advanced Reliability and Availability
    Double Device Data Correction - DDDC (Ready), this feature extends the capability to withstand failures in two x4 DRAM devices. DDDC can fix both single-and double-DRAM device memory errors.Standard hot plug redundant fans (3+1) and common-slot power supplies add high availability in the system.The latest flash backed write cache technology provides indefinite cache data retention as compared to two days retention with battery backed write cache in earlier generations.HP Insight Control helps administrators manage health proactively and in addition to new features like HP Memory Quarantine (which requires OS support), based on Intel's Machine Check Architecture (MCA) recovery, it empowers the DL580 G7 to be more resistant to errors in virtual environments.
  • Industry Leading Management Solution
    HP Insight Control measures, meters and caps power usage on individual and groups of servers to optimize power usage, driving significant gains to data center capacity.HP Insight Control now provides the ability to watch recorded boot and failure sequences, remote power on and power off, thereby enabling customers to dramatically reduce troubleshooting time, cost, and travel expenses. Functionality is provided by iLO Advanced.With HP Insight Control, you can reduce unplanned downtime by up to 77%.
  • HP Converged Infrastructure Approach
    HP is the only company to offer a full portfolio of standards-based, integrated solutions and services developed specifically to solve the complexities of the data center.By simplifying, integrating and automating technology, Converged Infrastructure accelerates outcomes that matter with: faster time to revenue; lower acquisition and implementation costs; flexibly respond to business changes and lower risks.
HPE ProLiant DL580 G7 High Performance - rack-mountable - Xeon E7-4870 2.4 GHz - 128 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, USB port control
Height (Rack Units)
4U
Region: Europe
Server Scalability
4-way
4 x Intel Xeon E7-4870 / 2.4 GHz (2.8 GHz) (10-core)
Processor Socket
LGA1567 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology, Intel Smart Cache
Cache Memory
120 MB L3 Cache
Cache Per Processor
30 MB
RAM
128 GB (installed) / 2 TB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i with 1GB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD
Graphics Controller
ATI ES1000
Video Memory
64 MB
GigE
Power Redundancy
Software Included
HP Insight Control
48.3 cm x 70 cm x 17.6 cm
30 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 4U
Server Scalability
4-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
Intel Xeon E7-4870
Clock Speed
2.4 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
10-core
CPU Qty
4
Max CPU Qty
4
CPU Upgradability
Upgradable
CPU Socket
LGA1567 Socket
Chipset Type
Intel 7500
Cache Memory
Installed Size
L3 Cache - 120 MB
Cache Per Processor
30 MB
RAM
Installed Size
128 GB / 2 TB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
64 (Total) / 48 (empty)
Registered, Memory Mirroring, Online Spare Memory
Configuration Features
16 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
1 GB
Optical Storage
DVD-ROM DVD - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Video Memory
64 MB
Integrated
Interface (Bus) Type
PCI Express 2.0 x8
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP NC375i
Remote Management Controller
Integrated Lights-Out 3
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
2 (total) / 2 (free) x PCIe 2.0 x16 - full-length, full-height (x8 mode) , 3 (total) / 3 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 8 (total) / 0 (free) x memory board
1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x USB 2.0 (2 front, 2 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 2 x VGA (1 front, 1 rear)
Administrator password, power-on password, keyboard password, serial port I/O control, USB port control
ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
Power supply - hot-plug
Power Redundancy
Installed Qty
4
Max Supported Qty
4
Power Provided
1200 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
Software
HP Insight Control
48.3 cm
70 cm
17.6 cm
30 kg
10 °C
35 °C
10 - 90% (non-condensing)
