HPE ProLiant N36L 1P 1GB-U Int SATA 250GB MICROSERVER
Quicklinx: 79YWWS00 Mfr#: 633724-421
  • Red Hat Enterprise Linux
Is your growing business ready for its first server to make you more productive and to enhance your success? The HP ProLiant MicroServer is a general purpose server that can provide a platform to organize and safeguard your business information, allowing effective communication with customers and making the most of your existing office equipment and resources. The HP ProLiant MicroServer is a cost-effective starter server for businesses with fewer than ten clients and it can take your business to the next level of productivity and efficiency. With a small form factor that is easy to use and service, it helps you drive down expenses while improving your success.
  • Simple To Own and Easy To Use
    The HPE ProLiant MicroServer provides your business with a server at personal computing costs, giving you more productivity for your dollars.The HPE ProLiant MicroServer is easy to install and service so that adding disk drives or peripherals requires a minimal effort for your staff.At a 22 dBA noise level, the ProLiant MicroServer is quiet for ergonomic working environments.The HPE ProLiant MicroServer form factor is space-saving, making it ideal for small office environments.
  • Reliability and Expandability
    The HPE ProLiant MicroServer offers a key feature called error checking and correction (ECC) memory, which reduces the likelihood of memory failures-a concern for your business.Supports RAID 0 and 1 which prevents data loss and facilitates around the clock reliability for your HPE ProLiant MicroServer providing peace of mind.With up to four large form factor (LFF) SATA pluggable hard disks and up to 8 GB of RAM the HPE ProLiant MicroServer gives you room to grow.
  • Proven HPE Dependability and Support
    HPE conducts some of the most rigorous and thorough testing in the industry for the HPE ProLiant MicroServer.System testing and process control the most dependable products.Backed by worldwide network of HPE trained service.
HPE ProLiant MicroServer - ultra micro tower Athlon II Neo N36L 1.3 GHz - 1 GB - HDD 250 GB
Server - ultra micro tower - system password
Region: Europe
Server Scalability
1-way
1 x AMD Athlon II Neo N36L / 1.3 GHz (Dual-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB (2 x 1 MB)
RAM
1 GB (installed) / 8 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 250 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
No optical drive
1GbE
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
21 cm x 26 cm x 26.7 cm
6 kg
Limited warranty - parts - 1 year - response time: next day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Ultra micro tower
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
1
Region: Europe
Processor / Chipset
CPU
Clock Speed
1.3 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB (2 x 1 MB)
RAM
Installed Size
DDR3 SDRAM - ECC
Effective Memory Speed
800 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 1 GB
Hard Drive
HDD
1 x 250 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express x1
Ethernet Controller
HP NC107i
Remote Management Protocol
IPMI 2.0
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 2.0 x16 - half-length, low-profile , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, low-profile , 1 (total) / 1 (free) x PCIe x4 , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU
1 x VGA , 6 x USB 2.0 (2 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 1 x eSATA 3Gb/s
System password
ACPI 2.0, WEEE
Power supply
Power Provided
200 Watt
Operating System / Software
OS Certified
Microsoft Windows Server, Red Hat Enterprise Linux
21 cm
26 cm
26.7 cm
6 kg
10 °C
35 °C
10 - 90%
Resources
The following resources are available for the HPE ProLiant N36L 1P 1GB-U Int SATA 250GB MICROSERVER
