HPE Proliant ML350e Gen8 v2 Intel Xeon E5-2407v2 4GB
Quicklinx: 9FZCWS00 Mfr#: 748953-421
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-ROM
Are you searching for a server to meet the requirements of your small- to medium-sized growing business? The HP ProLiant ML350e Gen8 v2 Server delivers exceptional value in a less than 24-inch chassis depth for a business with a limited budget. Designed as a dual-socket tower server, it provides essential performance and features with great configuration flexibility and expandability. With built-in innovations that simplify server deployment and management, your business can continue to reap the benefits on a daily basis, while expansion options allow you to grow as needed. Requiring only a low initial capital outlay, the HP ProLiant ML350e Gen8 v2 Server provides an excellent return on investment.
  • Right Essentials for the Budget Conscious
    The HPE ProLiant ML350e Gen8 v2 Server provides essential performance and features delivering exceptional value, ideal for a business with a tight budget.Supports up to two Intel Xeon E5-2400 v2 processors offering improved performance, efficiency and security.Designed to protect your investment, the HPE ProLiant ML350e Gen8 v2 Server is reliable and secure, with redundant storage and power supply options to increase system uptime.Latest HPE Smart Array Controllers are designed to maximize data availability, performance and capacity.
  • Designed to Grow with Your Business
    The HPE ProLiant ML350e Gen8 v2 Server has a chassis depth of less than 24 inches, saving precious real estate space.It allows your business to scale and grow with support for up to two processors, 12 DIMM slots, 16 small form factor (SFF) or 8 large form factor (LFF) drives, 6 PCIe slots, and 8 USB ports.The new NVIDIA Quadro K2000 GPU supports any dedicated graphics applications, giving you more value for your investment.It requires low upfront investment, while providing expansion capability to meet growing business needs.The built-in technologies not only automate mundane IT tasks, but also improve productivity and efficiency so the business can focus on growing.
  • Built-in Innovations that Simplify Management and Free Up Limited IT Resources
    With embedded management tools, the HPE ProLiant ML350e Gen8 v2 Server simplifies server management and maintenance tasks, enabling quick and simple deployment (HPE Intelligent Provisioning), system health monitoring (HPE Active Health System), and ease of firmware updates (HPE Smart Update Manager).HPE Smart Storage Administrator provides a single display screen for management and configuration of all HPE Smart Storage products and solutions.User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Socket guides, and tool-less access to components.
  • Proactive Service and Support to Redefine Service Experience
    The HPE ProLiant ML350e Gen8 v2 Server offers HPE proactive support services, which integrate industry leading performance, uptime, and productivity into a personalized, simplified support experience.HPE Insight Online with HPE Insight Remote Support provides 24x7 remote monitoring and anywhere, anytime personalized access to your IT and support status.Through HPE ServiceOne partners, you get responsive qualified partners to help you plan, manage and deliver solutions spanning the entire IT lifecycle.
HPE ProLiant ML350e Gen8 v2 Base - tower Xeon E5-2407V2 2.4 GHz - 4 GB - no HDD
Server - tower - administrator password, system password, power-on password, serial port I/O control
Height (Rack Units)
5U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon E5-2407V2 / 2.4 GHz (Quad-Core)
Cache Memory
10 MB L3 Cache
Cache Per Processor
10 MB
RAM
4 GB (installed) / 96 GB (max) - DDR3 SDRAM - Advanced ECC
Storage Controller
RAID (SATA 6Gb/s) - PCIe 2.0 x4 (HP Dynamic Smart Array B120i with 512MB FBWC)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD
Graphics Controller
Matrox G200
1GbE
20 cm x 63 cm x 43 cm
20 kg
Limited warranty - parts and labour - 1 year - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Tower - 5U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
4
Region: Europe
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
L3 Cache - 10 MB
Cache Per Processor
10 MB
RAM
Installed Size
DIMM 240-pin
Slots
12 (Total) / 11 (empty)
Unbuffered, low-voltage, HP SmartMemory
Configuration Features
1 x 4 GB
RAM Supported
PC3-12800 - 192 GB registered , PC3-12800 - 96 GB unbuffered - ECC , PC3-10600 - 96 GB - low voltage - unbuffered - ECC , PC3-10600 - 192 GB - low voltage - registered
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 2.0 x4
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Buffer Size
512 MB
Optical Storage
DVD-ROM DVD - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Input Device
No keyboard, no mouse
Integrated
Interface (Bus) Type
PCI Express 2.0 x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Protocol
IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
Bays
3 (total) / 2 (free) x external 5.25" x 1/2H , 4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
12 (total) / 11 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 1 (free) x SD card (internal)
8 x USB 2.0 (2 front, 4 rear, 2 internal) , 1 x HPE iLO , 2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x serial
Administrator password, system password, power-on password, serial port I/O control
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
Power supply
Power Provided
460 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Ubuntu
20 cm
63 cm
43 cm
20 kg
10 °C
35 °C
10 - 90% (non-condensing)
9FZC C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
