HPE ProLiant ML350 Gen10 Tower Intel Xeon Bronze 3204 8GB
Quicklinx: F8M1WS00 Mfr#: P11048-421
Case Style: Tower
Processor Type: Xeon Bronze
Hard Disk Capacity: 0GB
Processor Speed: 1.9GHz
Installed Memory: 8GB
£1,038.39 ex VAT
£1,246.06 inc VAT
Driving a wide range of workloads with a flexible, shorter and rackable chassis design that can fit in different physical environments, the secure HPE ProLiant ML350 Gen10 server delivers the ideal set of performance and expandability for changing business needs making it the choice for growing SMBs, remote/branch offices of large enterprises and data centers.
HPE ProLiant ML350 Gen10 Sub-Entry - tower - Xeon Bronze 3204 1.9 GHz - 8 GB
Server - tower
Height (Rack Units)
4U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon Bronze 3204 / 1.9 GHz (6-core)
Cache Memory
8.25 MB L3 Cache
Cache Per Processor
8.25 MB
RAM
8 GB (installed) / 768 GB (max) DDR4 SDRAM
Storage Controller
RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software RAID)
Server Storage Bays
Non-hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
GigE
17.4 cm x 64.8 cm x 46.25 cm
21 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Internal Bays Qty
4
Region: Europe
Processor / Chipset
CPU
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
8 GB / 768 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
12 (Total) / 11 (empty)
Registered, slots 13 - 24 are available in two-processor configuration only
Configuration Features
1 x 8 GB
RAM Supported
1.5 TB Load-Reduced , 768 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
14
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA, DisplayPort
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 369i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out Standard
Wake on LAN (WoL), ACPI support, PXE support
Bays
4 (total) / 4 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x microSD Card (internal) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode)
1 x VGA , 1 x serial , 1 x DisplayPort , 4 x LAN (Gigabit Ethernet) , 1 x HP iLO , 1 x HP iLO (1 in front) (service port) , 4 x USB 3.0 (2 front, 2 rear)
2 x fans
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
Power supply
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
500 Watt
Operating System / Software
OS Certified
CentOS, Microsoft Windows Server 2012 R2, SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, VMware ESXi 6.5, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, SuSE Linux Enterprise Server 12 SP2, ClearOS, VMware ESXi 6.0 update 3
Software
HPE OneView Standard (free download)
ENERGY STAR Certified
ENERGY STAR Version
2.1
17.4 cm
64.8 cm
46.25 cm
21 kg
10 °C
35 °C
8 - 90% (non-condensing)
Case Style: Tower
Brand: HPE
Price Range Ex VAT: 1000 - 1500
