HPE ProLiant ML350 Gen10 Tower Intel Xeon-B 3104 8GB
Quicklinx: F7NXWS00 Mfr#: 877619-031
Case Style: Tower
Processor Type: Xeon Bronze
Hard Disk Capacity: 0GB
Processor Speed: 1.7GHz
Installed Memory: 8GB
  • Red Hat Enterprise Linux
£1,735.09 ex VAT
£2,082.10 inc VAT
Do you need a robust server for your SMB and remote offices? HPE ProLiant ML350 Gen10 Server delivers a secure dual-socket tower server with performance, expandability, and proven reliability making it the choice for expanding SMBs, remote offices of larger businesses, and enterprise data centers. HPE ML350 Gen10 Server leverages the Intel Xeon Scalable processors with up to 71% performance gain and 27% increase in cores , along with the 2666 MT/s HPE DDR4 SmartMemory supports up to 3.0 TB and 11% faster than 2400 MT/s. The shorter re-designed rackable chassis with multiple upgrade options provides flexibility that can expand as your business needs grow. It supports 12 Gb/s SAS, NVMe SSD, embedded 4x1GbE NIC with a broad range of graphics and compute options. Supported by the HPE Pointnext industry-leading service organization and ease of deployment, HPE ML350 Gen10 Server helps you transform to a digital business with more agility and all within your limited IT budget.
  • Perform with Unmatched Versatility
    HPE ProLiant ML350 Gen10 supports up to two Intel Xeon Scalable processors, starting from Bronze through Platinum, 4 cores expanding up to 28 core processors offering unparalleled performance.Up to 24 DIMM slots to support the 2600 MT/s HPE DDR4 SmartMemory, reducing data loss and downtime with the HPE Gen10 technology licensed Fast Fault Tolerance feature while increasing workload performance and power efficiency.It supports a wide range of solutions from Azure to Docker to ClearOS along with the traditional operating systems.GPU expansion supports up to four units to accelerate performance in VDI applications and machine learning for financial services, surveillance and security, educational and scientific research, as well as retail and medical imaging.
  • Expand When Your Business Needs Grow
    HPE ProLiant ML350 Gen10 delivers expandability with a wide range of drive upgrade options. Supporting 8 to 24 SFF or 16 SFF when mixed with optional 8 NVMe PCIe solid state drives, 4 to 12 LFF hot plug or non-hot plug drive options protecting your IT investment in hybrid environment.Large expansion capacity with (8) PCIe slots, (6) USB ports, 5U rack conversion, and power supply options.Embedded 4x1GbE and the choice of PCIe standup 1GbE, 10GbE or 25GbE adapters provide you the flexibility of networking bandwidth and fabric so you can scale and adapt to different needs as your business grows.
  • Security Innovations
    HPE ProLiant ML350 Gen10 is one of the HPE industry standard servers with major firmware anchored directly into the silicon security protection built in across the server lifecycle starting with Silicon Root of Trust.Millions of lines of firmware code run before server operating system boots. With Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to the server and reliably store artifacts used to authenticate the server.
  • Industry Leading Services and Ease of Deployment
    The HPE ProLiant ML350 Gen10 comes with a complete set of HPE Pointnext services, delivering confidence, reducing risk, and helping customers realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an effective solution. Professional Services enable rapid deployment of solutions and Operational Services provide ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
HPE ProLiant ML350 Gen10 Sub-Entry - tower Xeon Bronze 3104 1.7 GHz - 8 GB - no HDD
Server - tower
Height (Rack Units)
4U
Server Scalability
2-way
1 x Intel Xeon Bronze 3104 / 1.7 GHz (6-core)
Processor Socket
FCLGA3647 Socket
Cache Memory
8.25 MB L3 Cache
Cache Per Processor
8.25 MB
RAM
8 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
Storage Controller
RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
Server Storage Bays
Non-hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
Video Memory
16 MB
1GbE
17.4 cm x 64.8 cm x 46.25 cm
21 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Tower - 4U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Server Scalability
2-way
Internal Bays Qty
4
Front Accessible Bays Qty
1
Processor / Chipset
CPU
Clock Speed
1.7 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
Effective Memory Speed
2133 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, Online Spare Memory, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory, 6-channel memory architecture
Configuration Features
1 x 8 GB
RAM Supported
3 TB Load-Reduced - ECC , 1.5 TB registered - ECC
Hard Drive
No HDD
Storage Controller
RAID
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
14
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 369i
Remote Management Controller
Integrated Lights-Out Standard
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 4 (total) / 4 (free) x 3.5" LFF
Slots
4 (total) / 4 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x microSD Card (internal)
1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x USB 2.0 (1 internal)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
Power supply
Installed Qty
1
Power Provided
500 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, VMware ESXi, ClearOS
Sustainability Information
ENERGY STAR Certified
17.4 cm
64.8 cm
46.25 cm
21 kg
10 °C
35 °C
8 - 90% (non-condensing)
Warranty Packs (2)
F7NX HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,700.51
F7NX HPE Installation Service - installation / configuration In Stock £458.80
Internal Hard Drives (2)
F7NX HPE 4 TB Internal HDD 3.5" Midline SATA 6Gb/s In Stock £251.10
F7NX HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s In Stock £236.48
Other bundles (4)
F7NX HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack In Stock £196.94
F7NX HPE LTO-6 Ultrium 6.25TB RW Data Tape In Stock £41.77
F7NX HP iLO Adv incl 3yr TS U E-LTU In Stock £310.83
F7NX HPE Ultrium RW Data Cartridge LTO Ultrium 7 6TB 15TB In Stock £58.54
Case Style: Tower
Brand: HPE
Price Range Ex VAT: £1500+
