Do you need a robust server for your SMB and remote offices? HPE ProLiant ML350 Gen10 Server delivers a secure dual-socket tower server with performance, expandability, and proven reliability making it the choice for expanding SMBs, remote offices of larger businesses, and enterprise data centers. HPE ML350 Gen10 Server leverages the Intel Xeon Scalable processors with up to 71% performance gain and 27% increase in cores , along with the 2666 MT/s HPE DDR4 SmartMemory supports up to 3.0 TB and 11% faster than 2400 MT/s. The shorter re-designed rackable chassis with multiple upgrade options provides flexibility that can expand as your business needs grow. It supports 12 Gb/s SAS, NVMe SSD, embedded 4x1GbE NIC with a broad range of graphics and compute options. Supported by the HPE Pointnext industry-leading service organization and ease of deployment, HPE ML350 Gen10 Server helps you transform to a digital business with more agility and all within your limited IT budget.
Perform with Unmatched Versatility
HPE ProLiant ML350 Gen10 supports up to two Intel Xeon Scalable processors, starting from Bronze through Platinum, 4 cores expanding up to 28 core processors offering unparalleled performance.Up to 24 DIMM slots to support the 2600 MT/s HPE DDR4 SmartMemory, reducing data loss and downtime with the HPE Gen10 technology licensed Fast Fault Tolerance feature while increasing workload performance and power efficiency.It supports a wide range of solutions from Azure to Docker to ClearOS along with the traditional operating systems.GPU expansion supports up to four units to accelerate performance in VDI applications and machine learning for financial services, surveillance and security, educational and scientific research, as well as retail and medical imaging. -
Expand When Your Business Needs Grow
HPE ProLiant ML350 Gen10 delivers expandability with a wide range of drive upgrade options. Supporting 8 to 24 SFF or 16 SFF when mixed with optional 8 NVMe PCIe solid state drives, 4 to 12 LFF hot plug or non-hot plug drive options protecting your IT investment in hybrid environment.Large expansion capacity with (8) PCIe slots, (6) USB ports, 5U rack conversion, and power supply options.Embedded 4x1GbE and the choice of PCIe standup 1GbE, 10GbE or 25GbE adapters provide you the flexibility of networking bandwidth and fabric so you can scale and adapt to different needs as your business grows. -
Security Innovations
HPE ProLiant ML350 Gen10 is one of the HPE industry standard servers with major firmware anchored directly into the silicon security protection built in across the server lifecycle starting with Silicon Root of Trust.Millions of lines of firmware code run before server operating system boots. With Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to the server and reliably store artifacts used to authenticate the server. -
Industry Leading Services and Ease of Deployment
The HPE ProLiant ML350 Gen10 comes with a complete set of HPE Pointnext services, delivering confidence, reducing risk, and helping customers realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an effective solution. Professional Services enable rapid deployment of solutions and Operational Services provide ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
- HPE ProLiant ML350 Gen10 Sub-Entry - tower Xeon Bronze 3104 1.7 GHz - 8 GB - no HDD
- Server - tower
- Height (Rack Units)
- 4U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Bronze 3104 / 1.7 GHz (6-core)
- Processor Socket
- FCLGA3647 Socket
- Cache Memory
- 8.25 MB L3 Cache
- Cache Per Processor
- 8.25 MB
- RAM
- 8 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
- Storage Controller
- RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
- Server Storage Bays
- Non-hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- 17.4 cm x 64.8 cm x 46.25 cm
- 21 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Tower - 4U
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- 2-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
Processor / Chipset
- CPU
- Intel Xeon Bronze 3104
- Clock Speed
- 1.7 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
- Chipset Type
- Intel C622
Cache Memory
- Installed Size
- L3 Cache - 8.25 MB
- 8.25 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, Online Spare Memory, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory, 6-channel memory architecture
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 3 TB Load-Reduced - ECC , 1.5 TB registered - ECC
Hard Drive
- No HDD
Storage Controller
- RAID
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i SR Software
- Channel Qty
- 14
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 369i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out Standard
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 4 (total) / 4 (free) x 3.5" LFF
- Slots
- 4 (total) / 4 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x USB 2.0 (1 internal)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
- Power supply
- Installed Qty
- 1
- Voltage Required
- Power Provided
- 500 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, VMware ESXi, ClearOS
Sustainability Information
- ENERGY STAR Certified
- 17.4 cm
- 64.8 cm
- 46.25 cm
- 21 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
Internal Hard Drives (3)
HPE 1TB 6G SATA 3.5in NHP MDL HDD | In Stock | £96.97 |
HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD | In Stock | £237.80 |
HPE 300GB SAS 15K SFF SC DS-Stock | In Stock | £456.47 |
Other bundles (5)
HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack | In Stock | £200.05 |
HPE LTO-6 Ultrium 6.25TB RW Data Tape | In Stock | £32.63 |
HP iLO Adv incl 3yr TS U E-LTU | In Stock | £311.60 |
HPE Ultrium RW Data Cartridge LTO Ultrium 7 6TB 15TB | In Stock | £49.85 |
HPE ML350 GEN10 Redundant Fan Cage | In Stock | £195.13 |
