Does your remote or branch office need a server that delivers the essential availability and expansion to accommodate your changing business needs? The HPE ProLiant ML30 Gen9 Server is an affordable single-socket tower server that features value performance, expansion, and growth that is ideal for small businesses and remote branch offices.
Unlock Your Infrastructure's Potential with Easy-to-Use Integrated Management and Support
The HPE ProLiant ML30 Gen9 Server offers HPE iLO Management, a complete set of embedded features, standard on all ProLiant Gen9 Server products. Includes HPE iLO with Agentless Management, Active Health System, Intelligent Provisioning, and Embedded Remote Support.HPE Insight Control provides advanced management capabilities across the lifecycle of your HPE ProLiant server infrastructure. HPE iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while decreasing time-to-resolution.HPE Insight Online with Insight Remote Support provides 24x7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE Smart Update Solution reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes Smart Update Manager (SUM), and Service Pack for ProLiant (SPP), and other products. -
Near Continuous Data Protection
The HPE ProLiant ML30 Gen9 Server Smart Array options provide businesses RAID mirroring and striping capability to protect critical data while the Flash-Backed Write Cache (FBWC) captures and holds data indefinitely in the event of a power loss, equipment failure, human error or virus attacks.HPE Smart Drives improve serviceability and prevents data loss with features such as icon-based status display and Do Not Remove LED.ECC memory protects businesses from data loss and unplanned system downtime. -
Flexible Options To Meet Changing Business Needs
The HPE ProLiant ML30 Gen9 Server provides HPE SmartDrives which offers more drive options including eight Small Form Factor (SFF) and four Large Form Factor (LFF) drive cages giving you flexibility for increased capacity for your local storage. Support up to 8 TB per slot.It supports 2400 MHz DDR4 memory, with up to four DIMMs (64 GB maximum) for increased performance.Four PCI Express (PCIe) slots, including four PCIe 3.0 slots, provide additional I/O performance. -
Seamless Network Connectivity Extends Benefits of Converged Infrastructure
The HPE ProLiant ML30 Gen9 Server offers compatibility with 24-port HPE 1810 Series Switches to enhance both connectivity and data availability.Common pool of resources and applications results in a higher level of simplicity and flexibility in operations.User-friendly interface on HPE PS1810 Series Switches allow for a consolidated view of servers and switches in the network so workloads can be prioritized.
- HPE ProLiant ML30 Gen9 Performance - micro tower - Xeon E3-1230V6 3.5 GHz - 8 GB - no HDD
- Server - micro tower
- Localisation
- Region: United Kingdom, Europe
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1230V6 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB L3 Cache
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-19200
- Storage Controller
- RAID (SATA 6Gb/s) - PCIe x4 (HP Dynamic Smart Array B140i)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- 17.5 cm x 47.52 cm x 36.82 cm
- 13.56 kg
- Manufacturer Selling Program
- HPE Top Value
- Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site
- Server
- Product Form Factor
- Micro tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1230V6
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- L3 Cache - 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 64 GB unbuffered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe x4
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B140i
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-RW DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HPE 332i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 0 (free) x external 5.25" , 4 (total) / 4 (free) x hot-swap 3.5" LFF
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x4 - full-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x VGA (1 rear) , 2 x LAN (Gigabit Ethernet) , 1 x LAN (Gigabit Ethernet) / HP iLO , 6 x USB 3.0 (4 front, 2 rear) , 4 x USB 2.0 (2 rear, 2 internal)
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
- HPE Top Value
- Power supply
- Installed Qty
- 1
- Voltage Required
- Power Provided
- 460 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 92%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 17.5 cm
- 47.52 cm
- 36.82 cm
- 13.56 kg
- 0 °C
- 40 °C
- 10 - 90%
Internal Hard Drives (1)
HPE Midline 4 TB - SATA 6Gb/s HDD | In Stock | £171.97 |
Other bundles (2)
HPE HP Ethernet 1Gb 4-port 331T Adapter | In Stock | £81.28 |
HPE HP Ethernet 1GB 2P 332T Adaptor | In Stock | £39.09 |
